Brake pad installation cost
Old Aug 30, 2010 | 03:30 PM
smn's Avatar
smn
hey guys, i have all 4 brake pads and i'm looking to have them installed. i called the dealer by me and they want almost $300 (install + resurfacing of the rotors). that seems a bit much. i'm in the new york area; anybody with any good experiences or recommendations?
Old Aug 30, 2010 | 11:13 PM
xaznperswaesonx's Avatar
do you have some tools? if you do .. mind waiting a couple days? I'm awaiting for my rear brake set to come in. I plan on doing a DIY on brakes for our car.
Old Aug 30, 2010 | 11:44 PM
psteng19's Avatar
For $300 you can get a new set of higher quality pads and rotors.
Installation is an easy DIY.
Old Aug 31, 2010 | 12:52 AM
kodawg9's Avatar
There is no way it should cost $300, even in New York.
Maybe post in regionals to see if anyone around you is willing to do it for you, because I know it's pretty commonplace that one installs their own rotors.
Old Aug 31, 2010 | 01:44 AM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
$300 for all four pads/rotors is NOT unreasonable to my knowledge. It might be high, but not unreasonable, for the stealership.
One advantage when you get this done at the stealership is that they resurface the rotors while they're mounted on the car.
Old Aug 31, 2010 | 11:25 AM
jwood_06TSX's Avatar
I just bought pads and rotors for all 4 corners at Autozone for $260 and had my long time mechanic put them on for $140. I thought that was a pretty darn good price for everything that stops as good as stock from what I can tell so far having driven with them for almost a week. I got the Duralast rotors and pads (the C-Max ones).
Old Aug 31, 2010 | 12:48 PM
smn's Avatar
smn
yes i have some tools and i'm willing to try it myself. the only thing is i couldn't find a DIY on this. it would be awesome if you could help me (and i'm sure others) out.
Old Aug 31, 2010 | 12:50 PM
smn's Avatar
smn
the $300 price was just for the brake pad installation (i'm keeping the stock rotors) and resurfacing the rotors. the price w/o resurfacing is $240.
A local car shop is asking $120 for the install but won't resurface the rotors (the mechanic didn't even know what i was talking about)
Old Aug 31, 2010 | 02:32 PM
Excelerate's Avatar
Former Sponsor
If you want to drive to our shop we can install the pads for $150. Just give us a call to set up an appointment.
Old Sep 1, 2010 | 10:05 AM
In matter of fact, my order should be here this week or early next week. I'll have a pad & rotor replacement DIY.
Old Sep 1, 2010 | 10:11 AM
and btw 300 for labor to replace pad & resurface rotor is a lot .. ridiculously a lot.
Old Sep 1, 2010 | 01:50 PM
smn's Avatar
smn
yea, it really is. i called a 2 brand name shops (midas & meineke) and the price quotes are pretty close to the $280 range.
does anyone know how bad it is if you don't resurface the rotors when installing new brake pads?
Old Sep 2, 2010 | 01:43 PM
super4's Avatar
first of, if a shop doesnt know what resurfacing is dont go there! rotors rarely need resurfacing, and changing pads is very very easy, u need a socket wrench (14 and 12mm socketts and i think a 16? or an adjustable whench) a c-clamp and a caliper turning cube for the rear calipers, but honeslty its not worth the hassel sometimes. a fair price is no more than 120. it took me about an hour and a half with hand toold and a floor jack to change all 4 corners. a shop, obviously using a lift and air tools should do the job in 40 min to an hour, hence just as how much they charge per hour labor (about 60-80 in nyc). but of course this is nyc and every shop and everyone is prerty much a jerk and is gonna try to rip you off.
Old Sep 3, 2010 | 12:35 AM
ck123's Avatar
doing brakes is ridiculously easy.....
if you see someone do it after you paid for the installation, you'll kick yourself in the head!!!
youtube is your friend for lots of car DIY. this is for a honda pilot but basically the same process
http://www.youtube.com/watch?v=eQ_LWihqh3c
Old Sep 3, 2010 | 02:32 AM
^^ very good vid but missing a lot of minor details that will save you headache in the long run.
waiting on Fed ex for my brakes from Heeltoe!
Old Sep 3, 2010 | 09:18 AM
2.4TSX-R's Avatar
if you don't have a piston clamp, just pull the bleed cap & take the bleeder out. Let little bit of fluid out, piston go back in
Old Sep 3, 2010 | 06:27 PM
feuss2's Avatar
10001110101
My rear pads disappeared quickly, (around 40k) and the wear on the rotors was very even so I just put on new OEM pads. No problems as a result. When it was time for the second set of pads on the rear, I just replaced the rotors at that time, with Brembo blanks for $54 ea at Tire Rack.
The fronts pads lasted beyond 90k, and I replaced the pads and rotors together. The front has considerable more stopping power, and read enough times about the OEM rotors warping after being cut. I figured there was no point in potentially adding the cost of resurfacing on top of the rotors I was eventually going to buy, and doing the job twice instead of once...
Old Sep 5, 2010 | 01:06 AM
DIY Brake & rotor replacement done. enjoy!
https://acurazine.com/forums/1g-tsx-performance-parts-modifications-126/diy-brake-pads-rotor-replacement-790452/
Old Sep 7, 2010 | 05:06 PM
smn's Avatar
smn
thanks dude!
Old Sep 8, 2010 | 12:14 AM
you're welcome!
mav888
1G RDX (2007-2012)
Sep 8, 2015 11:49 AM
asahrts
Sep 4, 2015 05:55 PM
nishant11
Sep 2, 2015 10:34 AM
