Brake dust/rust
Old Dec 10, 2004 | 06:02 PM
jojo77's Avatar
Brake dust/rust
Anything I can do to prevent it? I got a bunch of orange splotches on my brake discs. I heard you can buy brake discs that doesn't cause brake dust.
Old Dec 10, 2004 | 06:23 PM
Xtremespeed2102's Avatar
i have an island made out of jello....would you like to buy that???
lol im just messin with you
buttt those discs are probably alumnium but the best ones are always going to rust, the type of metal always rusts....chemical rxn
Old Dec 10, 2004 | 06:28 PM
Viking's Avatar
Quattro in.....
All rotors tend to do that here is a thread already discussing this:
https://acurazine.com/forums/showthr...ght=brake+dust
Old Dec 10, 2004 | 06:43 PM
Dr.Evil's Avatar
Arm the " Laser "
Move out of Seattle ....
damn Seattle Rain Festival
who took away the sun!!!!
Old Dec 12, 2004 | 04:53 PM
fear's Avatar
Cast Iron + Water + Heat = Rust
Cast Iron + Water + Salt + Heat = Lots of rust
Short of moving somewhere without oxygen there's nothing you can do....
-Fear
Old Dec 13, 2004 | 06:22 AM
sauceman's Avatar
Moderator Alumnus
No brake discs are ever made of aluminum. Aluminum is just way too porous to withstand the stresses a rotor has to bear with.
For the very large majority of production cars, they are made out of cast iron... and they will always rust, no matter what.
Old Dec 13, 2004 | 01:17 PM
TSXey's Avatar
Nick
True, most decent rotors are made from cast iron or some steel alloy and they all rust. If I let any of my disc brake cars sit for a few days, a thin layer of rust starts to build. First time or two that you apply the brakes, the pads will clean the rust off again.
If the rust bothers you that much, you could invest in a set of carbon rotors that will never rust. Some of the new high end Ferrari's and Porsches and such offer carbon brake rotor options. If you can find a deal, you may slide in under the $10,000 for a set of four.
Old Dec 13, 2004 | 02:47 PM
gpsiir's Avatar
Pity you can't make them out of stainless steel, but I'm sure there is some reason or other (heat resistance or somesuch).
Old Dec 14, 2004 | 09:57 AM
fear's Avatar
Cast iron is cheap, very strong if cast correctly and easy to machine.
Stainless, depending on the alloy can't be cast so you'd end up literally having to machine the whole rotor from a solid block. You'd even have to machine the venting in front rotors. That'd be very complicated and expensive. Stainless is also not easy to machine. Then there's the much greater tendency for stainless to warp.
But they would be pretty!
Old Dec 14, 2004 | 12:18 PM
jojo77's Avatar
is that it? In that case let me get a box.
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
rockyboy
Oct 2, 2015 10:45 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
2ManyHobbies
Sep 24, 2015 09:23 PM
