Automatic windows and Sunroof
Is it possible to change the switches to all four windows to make them one touch up and down??? the same for the sunroof. . . I would love for the sunroof to be one touch up/down!
I doubt it's software
You could feel how the switch has two settings on it. . . software controlled one touch would be two expensive. . . it's gotta be the switch. . . anyone out there know for sure?
Ok I just checked the service manual (pages 22-196 through 22-198) and there's no way you can just change the switch to enable auto down for the other windows. The driver's side window switch feeds into pins 4, 11, 17, and 23 of the master switch connector. Pins 4 and 17 send out the signal for an auto down or auto up. Pins 11 and 23 are used for the regular up/down functionality. All other windows only have two spaces on the master switch connector. There is no physical means of sending a signal to the window motors on the other windows to go auto up or auto down.
If you want them to go auto up or auto down you're going to have to get pretty creative.....
I still dont understand why they wouldnt at least have included the passenger window with auto touch. How much extra would it have cost at the factory, like 15 cents???
Maybe you could swap out switches, or get some from acura. Get three more driver side switches and swap them out. Then you would have enough pins on each switch, and could splice them with the drivers side front window.
I would really like this too.
I was thinking the same thing cmf....anyone have time to test this out. I would, but my TSX hasn't arrived yet! I am hoping it will come soon.
I don't understand why the sunroof doesn't have this? I thought just about every car has this feature except Honda/Acura. If they aren't putting the sunroof switch right under that sunroof, at least help the driver out a little and have it one touch.
Just my 2 cents.
Just my 2 cents.
Just my 2 cents.
Just my 2 cents.
It's not as simple as putting in switches with more pins. You would also have to redesign the relay panel to accommodate the extra functionality of those switches. And of course you would also have to take appart the door and run some wires but at that point this should be the simple part.
Joe Avesyan
09-29-2015 03:57 PM
