Another DICE vs USASpec question
After searching I've come to find out this topic has been beaten to death, so I preemptively apologize.
My question is how does each unit operate w/ regard to using the ipod directly. I understand the USA Spec unit needs to be switched over to DIRECT mode, how much of a pain is this? Furthermore, I've read that the DICE unit can be used on the steering controls, headunit controls, or on the ipod directly. I've also read the opposite in cconrads PDF file in this thread (second to last post), something to do w/ DIP switches? https://acurazine.com/forums/showthr...=646932&page=8
Any input and further clarification is appreciated
For me, I use my USASpec in a Folder+direct mode. I want the ability to control the iPod/iPhone from the device touchscreen. I don't use playlists or folders; I perfer to just select an artist and play from there. I just use the steering wheels to skip a song only. It work just the way I want it and I like it.
I think you might have to let folks know how you want to play your music to determine what system works best for you.
You shouldn't need to switch the DIP switches once they are set... would be a total pain to switch since I'm assuming the unit will be placed behind the cubby. The USASpec works great... you can use the iPod, steering wheel controls and use playlists. The only thing you'll need to do is switch your CDC disk to one of your six first playlists or put it on I think Disk 7 which allows you full control via the iPod. You'll still have another input on Disk 9 which allows you to add RCA inputs from satellite radio, HD radio or another audio source (DVD) as a growth option.
Rgoose18. you're getting no responses because this topic has been covered a million times. please use the search function. I have tried USA SPEC in my '06 but the install was difficult and Apple changes the iPhone firmware so much that it became very unreliable and dangerous to operate while driving. I just got a Kingston Liquid Aux with remote. no text on the head unit, but you can change tracks using their included remote. much cleaner and easier to install/operate. And kingston can spell.
I believe you're referring to the kensington liquid aux unit. I've seem that although I would like a more integrated system. I figure between dice and usa spec, since there is no majority I'll go w/ the company who can spell. DICE silverline it is.
Believe, on other forums I'm usually the guy flaming others for not searching, I did search. The data on these two setups was a bit inconclusive, hence the reason for this thread.
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
navtool.com
09-25-2015 05:15 PM
