07 5AT shifting issues!!! help please.
so my 07 5AT has been shifting funny. ever since the below zero weather in chicago..........
in 1st, it revs to about 3k with gentle acceleration but stutters when it shifts to 2nd. it floats around 3k - 3.5k before shifting..
when im about to come to a complete stop, it feels like it tries to engine brake that last few mph before i come to a complete stop.. kinda noticed that it goes away after the car is thoroughly warmed up.. anyone else got this issue?
I never worry about funny things that cars do before they're warmed up when it's extremely cold. If you feel an irrepressible urge to do something about it, flush the transmission fluid and refill.
i think its a little to premature to flush the trans fluid.. only have 10k clocked on it.
it was really weird when i floored it and it actually revved up to 5k before dropping down 3k rpm and then actually spinning the wheels forward.. it was almost like it netral dropped itself.....
Originally Posted by LAHORE1
I had a similar issue in Tampa when it was like 30 degrees a couple months ago......dealer changed powersteering pump (go figure) but fixed the issue.
Here's an idea.. take it to the dealer and have it checked under warranty.
Over the top? No. Why would you be excessively concerned about a behavioral quirk under conditions that are not all representative of normal operating conditions (an edge case scenario in the parlance of computer engineering)? If the situation resolves itself completely once normal conditions are achieved, I don't see a lot of reason to be concerned.
The temperatures in the mid-west have been hanging out around 0 (and it's been windy as all hell) for the last couple nights. Automatic transmission are almost always less smooth when they're very cold. It sounds like the servos are just having a hard time pushing the cold, thick fluid through the hundreds of tiny passages inside the transmission.
If it continues to act funny when it's warmer, then I'd be a little concerned. In these conditions, I wouldn't. Just let it warm up a little longer before driving.
Did you have your VSA on? I believe thats the VSA kicking in and also the DBW lag.
Perfectly normal. You can't expect to start a car and just go out and drive it in 0 degree weather conditions and expect it to perform as if it's 75 degrees.
Originally Posted by weeeerd
Hey.. there is actually someone on here with common sense..
I don't know where you're at Simba but it's been extremely cold in the Midwest through the north east. The OP stated he's in Chicago and it's probably been extra cold there. I wouldn't expect transmission funniness in 15 to 25 degree weather as it's not all that cold. Sub zero temperatures on the other hand are enough to turn your ATF into molasses. My 6mt has even been noticeably stiffer in the morning lately.
T.DoT P.I.M.P. lol
1 Post
The thread title is misleading because it's not a shifting issues.
I'm in Toronto, Canada. Temp is around -12c right now, with wind feels like -25c... lol. I will stop whinning.
Anyways, this will happens when your car is not warm-up (enough). When I get out in the morning, I started my car to warm up, and I have a cig. Took me about 3-4mins to finish, then I jump into my car and go. Sometimes when I'm in a hurry and skip the warm up section, the rpm will spark in 2nd --> 3rd gear; from 3K rpm to 5K rpm. However, this will NOT happen if you go very gentle on the gas even in SS.
thanks for the reply.. im gonna head to the dealer this weekend when it gets a little warmer.
I think it's less the ECU hesitating than it is the actual mechanics of the transmission operating slower than usual due to the extreme temperatures. And FYI, idling in park doesn't do much to warm up the ATF.
this gets better. last nite, it was super sluggish. doesnt want to climb the RPMs when u floor it. so i tried SS mode, i dont even have a indicator on what gear its on............
cant wait to explain this one to the dealer tomorrow. i think the snow and ice and get stuck revving and spinning for 20 mins did some work on the trans...........
now... worst case scenario
i dont want a remanufactured trans in a 2007 car.. can i somehow get the dealer switch out my car completely?
So what, you turned VSA off and floored it for 20 minutes or something? If so, congratulations, you just killed your transmission.
There's definitely something wrong though with these new symptoms. You'd be very, very unlikely to get a new car out of this.
i had the VSA on and off trying to get out.... But VSA doesnt really help u get out of a little ice trench.
anywho... the transmisson acted up before i even killed it. i didnt have the gear indicator on before i got stuck in the alley.........
so lets see what happned tom. and hopefully i'll get a tL or a RDX for a loaner
Now, you are back-tracking yourself in saying that he should wait until normal operating conditions...
Further more... to the OP... why the heck are you sitting on a forum, asking these questions to TSX owners???
I'll say it again... take your 2007 Acura TSX, which is under manufacturer's warranty, to the dealer.
My initial advice was to do nothing. The flush was only suggested if he couldn't handle doing nothing. Quoting my original post: "If you feel an irrepressible urge to do something about it, flush the transmission fluid and refill." I think I was pretty clear. Please don't put words in my mouth.
Now with the new symptoms which had either not occurred yet or he just did not mention, I would say yes, take it to the dealer.
if u actually read the post, im heading to the dealer tom.
thanks for ur input
goon, never spin your wheels at high speed when trying to get yourself unstuck. Firstly it won't work. Secondly, when only one wheel is spinning, as most cars with an open differential will do when they get stuck somewhere, this is very rough on your transmission, particularly the differential.
im on here like most other peeps... hopefully learn something.
thanks for ur input
thanks for ur input
It's just that most of us owners, even the mechanically inclined ones, could never tell you what might be going-on inside as complicated a system as a transmission.
That's all.
In the meantime, the more you drive it like that the worse it gets.
What concerns me is that if you listen to some of the suggestions on the forum, then wait on the dealer thing, you may completely blow the trans.
Or what may happen, is after you've spent two weeks flushing the fluids, and ressetting the ECU...the dealer is gonna say "F-you, it's your fault for performing the wrong fixes, and not bringing it sooner" and charge you for the repair.
This is how people blow engines, transmissions, etc.
They go on mycarsforum.com, and someone tells them "put 150 shot of nitrous on there yo. It'll be phat."
Boom... no more engine.
IF Warranty, THEN Dealer as soon as humanly possible.
Period.
The way the issue was stated initially it sounded like a one time thing that had fixed itself. If it wasn't going to be possible to reproduce, there'd be little point in bringing it to the dealer. At this point the definition of the problem has changed and I'm in full agreement (as is the OP) that it's dealer time.
Your claim that the dealer would somehow deny warranty work because some one changed fluids on their own is ludicrous. They would have to be able to show that the changing of the fluids directly caused the failure.
My advice to not worry about what at the time was described as a one time occurrence under extreme conditions is perfectly reasonable as I think most of even the slightest mechanically inclined here would agree with. There just wasn't any reason to be significantly concerned about what was described. You seem to be suggesting that no one think at all about anything their car might do and instead panic immediately. Sorry, some of us know better.
Arguing with you is pointless and adds no information to this thread so you can call me stupid any way you want, but I'm done responding to you.
i've had the issue randomly last week. it acted up this weekend. drove it last nite to get my taxes done and havent gotten a chance to get to the dealer. i have no intentions for flushing or resetting guys. like i said, thanks for ur input guys and im heading to the dealer tom nit. and dont plan to drive it anywhere else.
there really is no pt for you two to argue who said what and its incorrect and what nots..
so i got my car back.. they swapped the entire transmisson out.
a piece of metal chipped out of a bearing, messed up the differential, and shot a hole thru the bell housing. dont ask me how the heck it happened but the dealer took care of it while i cruised for a week in a 08 MDX .. SWEET!
now just gotta wait for the weather to clear and mount my RonJon Devotions !
I don't think that this requires a new thread but my '06 nbp does this too and I live in FLORIDA. Should this be happening? I let my car warm up to about 7rpm. We're talking a good 6 min in the car before take off. It was suggested to change transmission fluid.
Slightly unrelated, but last time there was a crazy snowstorm in Toronto, I was at an intersection and this Azn kid in a Audi A4 (non quattro) kept spinning his wheels (as in flooring it) trying to get traction turning left at a light. He had his windows down and had this smirk on his face thinking he was really cool. Well, when he was gone and I went through the intersection, this burning smell went into my cabin...I think his tranny was toast.
