transmission problem wont switch gear o highway
i think somethings wrong when im driving over 100 km onn the highway. when i try to pick up speed its revs higher then it should like 100 to 130 kmh its goes up to 5000rpm . its like it wants to switch into over drive but it wont. could overdrive be not working is that possible??
Please introduce yourself and your ride to us. As for your transmission problem, it could be numerous things. You can start by checking your fluid level if you haven't done so already. Your transmission could be slipping, or torque converter problem. Get a transmission shop to check it out. Welcome aboard!
No, the check engine light is not on. what do u mean by the present code thing?? I refuse to go on any highway now because the car just drinks the gas. on average how many km/miles do you guys get per full tank of gas???
My 2.5TL gets 25 mpg on road w/o lockup torque converter and around 22 mpg around town.
I meant Check Engine Light is always on and same code P0740.
Car has only 4 forward gears. Lockup may feel like a soft gear shift in some.
good luck
good luck
lock up torque converter?? i dunno somethings not right cus i drive like a grandpa and i get between 8 and 8.5 km a litre. i converted yours and it comes out to approx 10 km a litre. can a damaged torque converter cause me to burn more gas aswell??
It's a 4-spd trans w/ a LockUp torque converter. LU only locks engine to drive train (eliminating torque converter slip) and has no affect on gear ratio.
Depending on your driving habits 8.5 l/km is not horrible, particulary if LU is not working.
good luck
good luck
oh okay. thanks for the help. i believe its the converter or jus my tranny is slowly going cus even when it shifts gears it seems to jerk more then it should. and when im accelerating and let go of the gas it jerks a bit aswell. if my tranny is going does that interfere with how much gas i burn aswell??
yeah my car kind of had the same problem, it would just jerk alot when it would downshift and upshift from 2-3, it would rumble when i just park the car and sit there. i thought my tranny was slippin but i checked my tranny fluid and it was all bad so i went and got it changed and now its a ok
i got a freind to check the tranny fluid who use to fix hondas. he said the tranny fluid looks clean on the stick and is at an appropriate level. does the tranny even have a filter or are u talking about the oil filter?...thx
mada51589
Jan 9, 2025 04:40 PM
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
Mike Bertram
Sep 10, 2015 09:27 AM
HeloDown
Sep 8, 2015 06:51 PM
Do a drain and fill and filter replacement. See if that does anything.
