Timing belt change and have some questions
Old Dec 29, 2007 | 10:23 PM
vLude99's Avatar
7th Gear
Ok so I have already completed removing and installing the timing belt/water pump. However I noticed something I was not sure of.
What I noticed was that when everything is at cyl 1 TDC, I rotate the crankpulley 2 full rotations to get the camshaft pulley to be at cyl 1 TDC. Is that right? I thought it was 1 full rotation of crankpulley to get 1 full rotation of camshaft pulley.
I measured the pulley sizes and it is a 2:1 ratio which makes sense why it is doing that but something tells me this is not right.
Old Dec 30, 2007 | 09:39 AM
TexasHonda's Avatar
Yes, that is correct.
Crankshaft goes through 2 rotations to complete engine cycle (intake-compression-power-exhaust). Intake and exhaust valves must be actuated in coordination.
regards
Old Dec 30, 2007 | 06:18 PM
vLude99's Avatar
7th Gear
thanks texas, that helps alot.
Old Dec 30, 2007 | 07:32 PM
01tl4tl's Avatar
another reason I am going to pay someone else to do my 105k !!!
Old Jan 17, 2008 | 09:51 PM
95ildelsolsi's Avatar
Yeah, In a 4 cycle engine, the crankshaft rotates completely two times for each cycle, in a 2-cycle engine it's one rotation for each cycle.
merc009
Sep 14, 2015 06:43 PM
mav888
1G RDX (2007-2012)
Sep 8, 2015 11:49 AM
asahrts
Sep 4, 2015 05:55 PM
