Tail light stays on!
On my 96 tl 3.2. i noticed today after getting home from work that my tail light was on after i parked and cut the car and lights off. Had to pull the 20amp fuse to get them to go off so not to dain the battery.
What could cause my tail light to stay on?
I know rotors was almost under spec. when i did my last brake job. Will this make the tail light stay on if they were to go under spec.
By the way no CEL is on nor brake light.
Thanks for any advice in advance!
Mandy was right on the money with that brake switch stopper. im just hoping i can return the brake lamp switch since i bought it thinking it was the switch.
Here's a write up with picture from a honda fourm hope this is a help to others out their as this seems to be a common problem on acura and hondas.
http://www.honda-tech.com/showthread.php?t=2254546
Thanks again guys will be doing this small repair tomorrow
phuq, I paid 40 bucks for some dude to fix it a few yrs ago. If it happens, take off a battery terminal before you leave the car. this will turn off the light. if it stays on for hrs, it will drain your battery - just a FYI
blueninja: where in Houston are you at?
I need Help please!
I have a 1996 integra LS 4 door sedan. just bought it.
but i have a big issue with my tail lights and dashboard....:/ everything works fine, but when i turn lights on, it seems like im pressing the brake pedal...... when the light are off, i press break pedal and tail lights come on like normal. but when the lights are on, the taillight appear as if im pressing the break pedal, but im not.....???? they dont stay on like other typical issue that others have. mine go off when i turn them off and they stay off. but when i turn the light on, i repeat. it seems like im always pressing the brake pedal. so people behind me dont know when i brake. this is my daily driver. i hope you guys can help. thank you so much. in advance. oh and i already replaced the break switch....so it aint that.
mada51589
Jan 9, 2025 04:40 PM
handsom-hustla
Nov 13, 2015 05:04 PM
wusty23jd
Sep 24, 2015 11:41 AM
Ny1718
Sep 11, 2015 09:21 AM
