"NOK" injectors
Made a mistake and bought a beat up TL 2.5l 5c
replaced the starter to do so i figured the easiest way was to unhook the intake so did to all good starters done look at the injectors and there cracked on the bottom so im looking to repair them by replacing the hats and caps without replacing the whole injector. does anyone know of a kit that makes this possible?
any help would be appreciated also from the handful of post i read the harder then normal shift is going to be a bigger problem then anticipated
k6biv
Sep 10, 2015 06:37 PM
