Starter problems
Old Nov 11, 2007 | 11:45 PM
akuraowna's Avatar
5th Gear
Starter problems
Can somebody tell me where the starter is located on a 96 acura 2.5 tl. Thanx
Old Nov 12, 2007 | 06:19 AM
TexasHonda's Avatar
Yes, Acura conveniently placed it under the intake manifold near the rear of the engine. If you search my threads, you'll find some posts about my experience replacing my starter. It's not a terrrible job, but annoying due to access issues. Here's the link:
Starter Sticky Link, Page 3
What are your symptoms and issues?
good luck
Old Nov 15, 2007 | 03:27 PM
akuraowna's Avatar
5th Gear
when i turn the key all i hear is the solenoid click. Sometimes the car starts sometimes it doesnt. I already replaced the battery and bought a new starter.
Old Nov 15, 2007 | 04:55 PM
Go90go's Avatar
大日本帝国
^ Could be the main relay.
~Cheers~
Old Nov 16, 2007 | 04:00 PM
TexasHonda's Avatar
If you hear only a loud click when you turn key to Start, the most likely explanation is a bad starter, even though it's new. I would return to whoever installed your starter for support. Was this a rebuilt starter? From where?
If you diy, you may have to do the job again. Check battery connections and wiring to starter to make sure it was connected correctly.
good luck
Old Nov 18, 2007 | 11:08 PM
akuraowna's Avatar
5th Gear
Can u tell me what u did to break the 17mm bolt that mounts the starter to the car. I have tried everything and i just cant get the bolt out.
Old Nov 24, 2007 | 12:15 PM
TexasHonda's Avatar
The 17mm bolt is the outer (easily accessed but very tight bolt).
An air impact may be able to break if you have room (can't remember if there's room).
In my case, I had to remove the alternator out to create a "tunnel" under the manifold through which I threaded 3- 1/2" extensions. This allowed me space to use my ratchet w/ a cheater pipe to increase leverage and break the bolt loose.
good luck
Mike Pilipenko
Mar 26, 2024 09:21 PM
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
agupta3224
Sep 22, 2015 08:08 PM
