selling the tl but had to replace steering rack
Old Oct 28, 2010 | 10:08 PM
vip TL's Avatar
just got the mechanic to to install a rebuid sterering rack cost me 600 dollars with parts and labour, recently had outer tire rod and upper ball joint done and i did an alinement, and as i was going home on the freeway the car starts pulling on the passenger side, so i pulled over and give it a rest, then start driving again and in about 15 munites time it starts pulling again, any suggestion.
Old Oct 29, 2010 | 12:44 PM
bigwerm187's Avatar
Str8 Home built
they did a crappy job take it back thats wat happened.....
Old Oct 29, 2010 | 09:31 PM
vip TL's Avatar
did you had this problem before
Old Nov 1, 2010 | 10:30 AM
KaMLuNg's Avatar
when they reinstalled the rack, did they also do an alignment??? i was reading the service manual that when you reinstall the rack, it has to be perfect, or you will have alignment issues afterwards...
Old Nov 2, 2010 | 05:31 AM
vip TL's Avatar
yes i was there when the alignment was done, i have a feeling that the brake is seizing
Old Nov 2, 2010 | 08:52 AM
KaMLuNg's Avatar
is the wheel hot after driving the car for a while... if you can't even touch the wheel, most likely the caliper is seized...
Old Nov 2, 2010 | 11:04 AM
Mandy's Avatar
98 3.2 Flamenco Black
Plus 2^ Check your rims...if it is hot, the calipers are seized.
Old Nov 2, 2010 | 09:28 PM
vip TL's Avatar
no it's just normal, but if i drive it for about 20 min it just pulls on side and i get a little shiming from the steering wheel.
BreezyTL
Jul 26, 2016 12:52 PM
SpraykwoN
ILX
Sep 11, 2015 08:45 PM
asahrts
Sep 4, 2015 05:55 PM
FC2012RDX
1G RDX (2007-2012)
Sep 4, 2015 02:05 PM
MyKids&Cars
Sep 2, 2015 12:03 AM
