Noise like an antenna going up and down
Old Mar 16, 2006 | 02:36 PM
pdews2001's Avatar
Someone help, I just bought an 1996 Acura 2.5TL and it sounds like an auto antenna is going up and down, but there is no antenna
Old Mar 16, 2006 | 02:59 PM
KaMLuNg's Avatar
is it just shortly after u start ur car and about to move??? if so that is your ABS self testing...
Old Mar 16, 2006 | 03:05 PM
pdews2001's Avatar
sometimes it happens while Im sitting at a light or something like that its just speratic
Old Mar 16, 2006 | 03:08 PM
pdews2001's Avatar
Is there anyway to make it a little quiter
Old Mar 16, 2006 | 03:41 PM
ITL's Avatar
ITL
I do my own work.
take it off
and just do without ABS
Old Mar 16, 2006 | 03:49 PM
esco786's Avatar
at a stop light? probably when ur coming to a brake, ur abs pump is building pressure and thus making that sound. does ur abs light come on? that sound is definetly ur abs, having it come on once after turning on ur car is normal...but if more, not normal..keep me updated, ive been through this so i can help u
Old Mar 16, 2006 | 03:51 PM
ITL's Avatar
ITL
I do my own work.
I went through 3 ABS modulators on my old '96 Accord from a similar sounding issue. They NEVER figured out what it was. It was replaced twice under warranty and once out of my own pocket for about $1100. Good luck, friend.
Turns out the ABS modulator was a sub-system of the brake system, so I couldn't "take it off" and do without it
Old Mar 16, 2006 | 03:57 PM
esco786's Avatar
Originally Posted by ITL
take it off
haha, ya that'll be easy for ppl in southern US, but in goddamn canada, that shit has saved my life.
Old Mar 16, 2006 | 09:56 PM
HQuakers's Avatar
giggity giggity giggity
It might be the fuel pump. I have gone through 3 of them so far and it makes almost that exact same noise. It only really makes it when idling, not when driving.
Old Mar 17, 2006 | 02:55 AM
Ken1997TL's Avatar
Sounds like the fuel pump to me.
Old Mar 17, 2006 | 09:58 AM
pdews2001's Avatar
How much does it cost to replace the fuel pump?
Old Mar 17, 2006 | 10:36 PM
HQuakers's Avatar
Hmm, well you should probably ask someone else. I am having some issues right now with my replacement, but the pump should cost about $300, plus a new filter, and the install should be about an hour to an hour-and-a-half. Texashonda might be able to give you a better estimate. I would get it checked out first before self-diagnosing though because it will be about $500.
Old Mar 17, 2006 | 10:37 PM
HQuakers's Avatar
Also, did it make that noise before? Like when you test drove it? The reason I ask is because you probably have an aftermarket fuel pump in the car. The pump will work fine, the noise is just very annoying.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
rhdune16
Sep 28, 2015 11:31 AM
