Gauge Cluster
Old Feb 23, 2006 | 12:52 PM
TL BABY's Avatar
Gauge Cluster
I seem to have a problem. The lights in the gauge cluster does not turn on when I drive at night. The lights on the climate control, dome and all other interior lights work except theones in the cluster as well as the area where the the mirror controls are.
Does anyone know what the problem is? Any help would be much appreciated.
Old Feb 23, 2006 | 06:50 PM
TexasHonda's Avatar
Gauge lights run off #1 fuse in under dash fuse/relay box. The #1 fuse is lower row, 2nd fuse from left. The first fuse is a spare. It's unlikely that all 7 of them are burnt out.
Another possibility is the dash light brightness control. Have you checked to make sure it's not on minimum? The brightness controller can go bad and cause your problem also. You check the controller by checking for 12V on the red wire to the controller when dash lights should be on. If no voltage, problem is most likely the fuse or all the lights are burnt out. If voltage is present, the controller is bad and must be replaced.
good luck
Old Feb 23, 2006 | 07:50 PM
UnsanePyro's Avatar
Registered Driver
good luck
I had a dimmer go bad in my old Volvo, and had to drive around with a paper clip in the wiring harness for a while till I found a new one
Old Feb 23, 2006 | 09:37 PM
TL BABY's Avatar
good luck
Well I checked the brightness controller and there's nothing at all. I will check the fuse box, if there's still a problem, I will then take out the brightness control switch tomorrow. It's too dark for me to do that right now.
I really appreciate the feedback. You're definitely one of the more knowledgeable kats on this board.
thanks
Old Feb 24, 2006 | 08:35 AM
TexasHonda's Avatar
If you checked correctly the brightness controller is ruled out. As Unsanepyro points out, you can bypass the controller w/ a shorting jumper across the correct pins. You'll need a wiring diagram to be sure for your car.
Hopefully, it's the underdash fuse.
good luck
Old Mar 18, 2006 | 07:22 PM
TL BABY's Avatar
good luck
Update.
It turns out I had 2 bad switches. I took the switches from my other Acura and installed them in the TL and everything works fine.
Thanks to you TexasHonda, and UnsanePyro. you guys are knowledgeable kats.
Peace.
Jul 16, 2017 07:33 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
Retep Nitciaj
1G RL (1996-2004)
Oct 6, 2015 01:36 PM
brandnewcolony
Sep 12, 2015 10:39 AM
