no hot air
Old Dec 4, 2006 | 06:35 PM
acadia's Avatar
no hot air
My heater is not blowing hot air (although it does sometimes)
maalca@nbnet.nb.ca
Old Dec 4, 2006 | 06:47 PM
TexasHonda's Avatar
Turn keyswitch On, and press Auto & OFF buttons at the same time. The display will present a fault in code. There are previous posts on the code interpretation if you do a search on "climate control" or similar. You could look for posts under my name also and find the correct post.
good luck
Old Dec 5, 2006 | 12:40 PM
hoser's Avatar
Originally Posted by TexasHonda
.......... The display will present a fault in code.......
Will it give a code if the thermostat is bad?
Old Dec 5, 2006 | 07:07 PM
TexasHonda's Avatar
No, if engine is running cold there won't be a code stored. You can't make hot air w/o some hot coolant to circulate.
good luck
Old Dec 6, 2006 | 05:46 PM
acadia's Avatar
maalca@nbnet.nb.ca
I tried to get a code as you suggest but nothing appears.
Today I left my car idle for less then 5 minutes and when I got home there was steam coming out of the container where it should overflow and it was bubbling in it.
I tried something else, I speed the motor at 2500 rpm and hot air started to come in????????as soon as I got back to idle it turned again to cold air.
Old Dec 6, 2006 | 07:49 PM
TexasHonda's Avatar
Your car is low on coolant and may have a bad cylinder head gasket. Any recent overheating incidents? Get some coolant or coolant mix and make sure the system is full of coolant by slowly (very slowly w/ stops to allow air to escape) filling through the radiator w/ engine cold.
W/ engine and coolant cold restart car w/ radiator cap off and look for bubbles in coolant or a sudden coolant overflow from the radiator. If yes, a bad head gasket is very likely.
It could be you're just low on coolant and have a coolant leak somewhere (bad hose, bad water pump, etc).
good luck
SidhuSaaB
May 30, 2020 12:40 AM
tsx_boy
Dec 13, 2019 08:33 PM
rcs86
Aug 2, 2016 06:52 PM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
hashbrown
Sep 29, 2015 12:13 PM
