no hot air
Turn keyswitch On, and press Auto & OFF buttons at the same time. The display will present a fault in code. There are previous posts on the code interpretation if you do a search on "climate control" or similar. You could look for posts under my name also and find the correct post.
good luck
good luck
Originally Posted by acadia
Today I left my car idle for less then 5 minutes and when I got home there was steam coming out of the container where it should overflow and it was bubbling in it.
I tried something else, I speed the motor at 2500 rpm and hot air started to come in????????as soon as I got back to idle it turned again to cold air.
Your car is low on coolant and may have a bad cylinder head gasket. Any recent overheating incidents? Get some coolant or coolant mix and make sure the system is full of coolant by slowly (very slowly w/ stops to allow air to escape) filling through the radiator w/ engine cold.
W/ engine and coolant cold restart car w/ radiator cap off and look for bubbles in coolant or a sudden coolant overflow from the radiator. If yes, a bad head gasket is very likely.
It could be you're just low on coolant and have a coolant leak somewhere (bad hose, bad water pump, etc).
good luck
good luck
SidhuSaaB
May 30, 2020 12:40 AM
rcs86
Aug 2, 2016 06:52 PM
