no crank,and no shift problem
Old Sep 7, 2009 | 04:52 PM
crayonsmiff's Avatar
my car is a 97 tl 2.5,when iu try and start it it does not turn over.and will not come out of park,i dont know what to do,i have checked everything i know of fuses,relays,came up w nothing help!
Old Sep 7, 2009 | 06:07 PM
main70072's Avatar
What kind of noises if any do you hear when trying to start it? Are there any lights on the dash? Have you been able to shift out of park prior to having problems with starting the car? In order to shift out of park, you will need to press the brake pedal. There is a brake switch that disengages the lock on the shifter.
Old Sep 8, 2009 | 09:13 AM
andrew070489's Avatar
put your key into that little slot, move the shifter to neutral. then try to start your car. it will probably start, if it doesnt either starter or battery i bet. battery - car will just be totally lifeless, no lights, etc. starter - everything will work but wont crank.
Old Sep 12, 2009 | 12:53 PM
SurfingScotty's Avatar
2007 6SMT Type-S
I'm having a similar problem, only mine DOES turn over. The ignition gets power, but as soon as the car starts to run on its own, the power to the ignition stops. I too, can't shift out of park. Also, when I turn the key on, I don't hear that usual electrical "whine" which I think is the fuel pump priming or something?
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
JDMVP
1G TL (1996-1998)
Sep 17, 2015 06:14 PM
whitesoxsfan12
Sep 13, 2015 02:09 PM
HeloDown
Sep 8, 2015 06:51 PM
NSolace
Sep 3, 2015 08:14 PM
