need help guys
Old Nov 12, 2007 | 01:23 PM
96GATL's Avatar
need help guys
yea i was wondering what would be the cost of another motor for a 96 TL.......
cause im trying to buy a new one and i dont knoe much about TL's so see what yall can do and let me knoe
Old Nov 12, 2007 | 01:51 PM
Go90go's Avatar
大日本帝国
I'll let you "knoe". It's can be as much as $2000, down to $500. Installing it will run about another $2000 from a shop.
Write smaller and not in red. Red text on a forum means sarcasm.
~Cheers~
Old Nov 12, 2007 | 06:12 PM
TexasHonda's Avatar
It will also depend on model 2.5TL or 3.2TL. Check car-part.com for used engine prices. Find a used engine installer that will insure the engine and his labor.
good luck
Old Nov 14, 2007 | 02:30 PM
BT TL's Avatar
I just had a mechanic replace my engine (1996 2.5 TL).
You can get a used engine for about $1,000 and the labor was a little over $1,000.
Old Nov 14, 2007 | 02:50 PM
Go90go's Avatar
大日本帝国
^ I got a quote from a shop to do mine and it was $2300 labour with a discount. I ended up doing it myself.
~Cheers~
Old Nov 14, 2007 | 03:33 PM
96GATL's Avatar
would it be hard to do yourself!!!
but then LMK cause im new to this guys.....
i know how to swap hondas and acuras but then not to sure about the TL's and so on
Old Nov 14, 2007 | 08:28 PM
KaMLuNg's Avatar
if u have done a swap before and u are doing a direct swap of the same engine... it shouldn't be hard for you...
Old Nov 15, 2007 | 02:31 PM
Go90go's Avatar
大日本帝国
^ Yup. Just take pictures and remember to label where everything goes.
~Cheers~
Old Nov 15, 2007 | 07:34 PM
TexasHonda's Avatar
It doesn't look like a terrible job, but I was unsure about how to remove the extension shaft. The manual calls for a special puller which I could not locate. How is this step managed?
regards
OculiAquilae
Nov 19, 2018 02:24 PM
funkbro2
Nov 17, 2015 10:23 PM
knight rider
Oct 1, 2015 10:29 AM
ja4lyfe
ZDX
Sep 17, 2015 09:10 AM
Nicho863
Sep 3, 2015 09:16 PM
