my a/c stopped working!
Old Jul 9, 2008 | 07:44 PM
l-train's Avatar
it worked fine yesterday, but today it stop blowing anykind of air.. i could live without a/c but not without defogger.. i search the forums but most of it has air coming out.. any suggestions for me? how much is it to change a compressor + part?
i have a 97 tl 2.5
Old Jul 9, 2008 | 08:42 PM
KrayzieDxC's Avatar
Khmer Pride
ac recharge?
Old Jul 10, 2008 | 01:34 PM
l-train's Avatar
i dont think that is it... i try it before but still no air coming out the vents.. any other suggestions
Old Jul 10, 2008 | 03:13 PM
KrayzieDxC's Avatar
Khmer Pride
the blow motor in the dash..dead
you can try d/l the service manual..theres a trouble shooting guide it will tell you whats the problem
Old Jul 10, 2008 | 03:57 PM
01tl4tl's Avatar
no interior fan when you turn it on?
check the fuses first!
then check the conneter for the fan motor- I am gen2, and ours get overheated and melt!
There is also a resistor for the blower motor.
on gen2- so may be same for you- remove glovebox door and glovebox (see gen2 diy Cabin air filter) and the blower motor is down there- the heater and ac next to it
a few bolts hold it in and the resistor is on the back- the connector usually on the front
Old Jul 24, 2008 | 03:07 PM
l-train's Avatar
the mechanic said its something with the fuse.. anybody know wheres the fusebox?
Old Jul 24, 2008 | 03:11 PM
KrayzieDxC's Avatar
Khmer Pride
its near driver door ,underneath or under your hood near the corner of the pass.
Old Jul 24, 2008 | 03:15 PM
l-train's Avatar
i know theres under the hood, but is there another one in the car
Old Jul 24, 2008 | 03:23 PM
KrayzieDxC's Avatar
Khmer Pride
Old Jul 28, 2008 | 10:00 PM
fxmech's Avatar
I am having the same problem. If you set the ac to get air from outside (not recirculate) and set it to cold, when you drive over 50mph you can feel the ice cold air blowing through the ac system. This tells me that the AC is working fine but the ac's fan/blower is not working at all. lAlso once in a while if I have the ac on but there is no air comming out and I drive over a speed bump, it will loosen up the fan and it will start blowing for a while untilll I turn it off again. It sounds like its is maybe worn out bearings in the blower motor assembly. Any one know where this fan is at on a first gen TL and how to replace it????
Old Aug 27, 2008 | 08:27 PM
Alexander124c41+'s Avatar
^_^;
Kick panel near your left foot... turn the little knob and view the fuse diagram... use a fuse tester or a multimeter to test continuity of the fuses in that box...
Old Sep 7, 2008 | 01:03 AM
l-train's Avatar
yeah thanks for the input till this day i haven't fix it yet,, i need the defroster bad.. im thinking of changing the blower motor or something.. my fans comes on but no air come out at all from the vents and sometimes i think theres a lot hot air by the petals or something..
Old Sep 7, 2008 | 12:08 PM
01tl4tl's Avatar
if the fan comes on but no air flows- you likely have a door control problem
The control for the position of what vents are open-- to allow air from/to different points
A control cable or a main door near the blower must be stuck
Start at the blower motor and search from there- you could blow compressed air thru the system to see where it stops
check the motor for free spinning of fan and the electrical connection for its power and the resistor for the motor
Im guessing based on what happens to gen2s
Old Sep 8, 2008 | 12:05 AM
LDH's Avatar
LDH
I
I had the same problem on my old 1st gen. My system just cut out one day while I was making a left turn, and a few months later when my dad's mechanic was changing the spark plugs I asked him to help me diagnose the problem, and he told me that the A/C was blowing ice cold air and worked fine and until this day it worked fine.
01CLOwner
Oct 9, 2015 01:07 PM
SilverJ
1/2G MDX (2001-2013)
Sep 21, 2015 02:40 PM
acurajj
Sep 19, 2015 03:47 PM
theinsvnity
Sep 10, 2015 10:22 PM
dlknight
Sep 3, 2015 07:54 PM
