Fuse?
Old Jul 5, 2010 | 04:01 PM
hinode's Avatar
Fuse?
Is there a specific fuse that controls the windshield wiper fluid to come out? Thanks in advance...!
Old Jul 5, 2010 | 09:03 PM
Gergnoodle's Avatar
ummm not usually if the wipers still work its most likely a bad pump... on any ive changed the pumps are built into the washer reservoir
but hey it's japanese there could be one maybe in the box under the hood
Old Jul 6, 2010 | 07:01 AM
TLin401's Avatar
'13 Hyundai Sonata
There's a pump inside of it. Well maybe the spray nozzles are clogged. Spray the fluid, see if you hear the activating noise. If nothing then you have bigger problems but if you hear something, then you can just unclog the nozzles.
Old Jul 7, 2010 | 05:18 PM
hinode's Avatar
Sorry...forgot to add that I got a 1997 2.5 TL.
Don't think I heard anything when I tried to activate the windshield wiper fluid...
What part am I looking for specifically if I am to replace it, and what's the degree of difficulty in doing so???
Old Jul 8, 2010 | 09:43 AM
Mandy's Avatar
98 3.2 Flamenco Black
Do you have washer fluid? Sure not empty? Do you hear the pump? Gotta open the hood and have somebody trigger the washer while you listen.
Old Jul 8, 2010 | 11:53 AM
TexasHonda's Avatar
Windshield fluid pump motor has probably gone if you don't have any fluid to the nozzles. Pull one tube end loose and check. Motor is conveniently located behind the pax side wheel well cover in the fender/body gap. Not terrible difficult to access and repair, but not as easy as most vehicles.
good luck
Acura604
20
Aug 5, 2017 12:55 AM
Skirmich
Oct 1, 2015 12:59 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
ripit
Sep 26, 2015 06:19 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
