Egr ports help
Old Apr 25, 2010 | 10:22 PM
DUECEON9ER's Avatar
Red face Egr ports help
Anyone know of a D.I.Y. for the First Generation TL of cleaning out the egr ports and removing intake manifold. Need your help, anyone who has done this maybe have some pics and advice. Basically need to know what stuff to remove and what gaskets to order. I own the 3.2TL. I have a general idea but do not want to run into any problems with replacement parts. I've had this problem since I bought the car and am dreading it. I finally want to get that check engine light off!
Can you guys help me please?
Old Apr 26, 2010 | 11:44 AM
Mandy's Avatar
98 3.2 Flamenco Black
You might still be under extended warranty, 150K and 14 years. Are you?
Old Apr 26, 2010 | 12:01 PM
DUECEON9ER's Avatar
Definitely not even close I'm at 176k already I do quite a bit of driving. Anyways found this online is this pretty much the same layout for the 1997 3.2 TL ....http://www.acura-legend.com/vbulleti...leaning-79886/ ......this is for a 1996 3.5 RL, what do you guys think? Sorry you can click on any one of the pics to get a better look as well.
Last edited by DUECEON9ER; Apr 26, 2010 at 12:02 PM. Reason: Information pertaining to website
Old Apr 27, 2010 | 03:23 PM
Mandy's Avatar
Sorry to hear you are out of warranty. Good luck.
Old Apr 28, 2010 | 07:16 PM
DUECEON9ER's Avatar
So no one can help?
Old Apr 30, 2010 | 09:06 PM
DUECEON9ER's Avatar
This thread has had 100 views as of right now and still no response from anyone WOW!! I guess only so few mechanically inclined. I like learning all I need is for someone to point me in the right direction.
Old May 1, 2010 | 07:13 PM
Mandy's Avatar
A friend mechanic told me it is easy to clean the ports. I will ask specific instructions and will schedule the cleaning and will do a DIY.
My CEL is on and it is annoying.
Old May 1, 2010 | 07:25 PM
DUECEON9ER's Avatar
Thanks Mandy really appreciate all the help been looking to find a way to do for more than a year now.
Old May 2, 2010 | 11:30 AM
9632tl's Avatar
Radical Member
Its not too hard. I had mine off to swap with the type2 manifold. My egr passage was almost completely plugged.
The plenum gaskets dont cost too much, but the manifold-to-head gaskets are REALLY expensive. $40 for each side.
I bought a headgasket kit on ebwy for $60, and it came with everything i neede, plus heagaskets.
Pm me, and i can try to send pictures
Old May 2, 2010 | 11:33 AM
9632tl's Avatar
Radical Member
Oh, and my intake manifold was super gross inside
Old May 3, 2010 | 02:04 PM
Mandy's Avatar
Please post pics. We need all the help we can get.
Old May 3, 2010 | 02:05 PM
Mandy's Avatar
I am trying to imagine the scope of this work, pics would be appreciated. Thanks.
The dealer wants $385 for the cleaning.
That P0401 CEL is annoying!
Old May 3, 2010 | 04:53 PM
9632tl's Avatar
Radical Member
Its hard for me to post pics on here from my phone (i dont often use my home computer) pm me your email address, and i can send them. I will take more when i get home.
Its sad that the camera on my phone is better than my digital camera!
Old May 4, 2010 | 07:18 AM
Mandy's Avatar
PM sent, thanks.
Old May 4, 2010 | 04:20 PM
Mandy's Avatar
Pics received, great! More pics appreciated.
Old May 5, 2010 | 06:54 PM
Mandy's Avatar
9632tl thanks for your pics! I will post yours and mine and please check it out. See my other post, please. I think I know what to do.
Old May 5, 2010 | 07:22 PM
Mandy's Avatar
I posted pics on my EGR post. Check it out.
Old Jun 2, 2010 | 02:29 PM
Mandy's Avatar
Well my cleaning did not resolve my CEL P0401. It comes back a few miles after I reset it.
Mandy's Avatar
I have to try cleaning the EGR valve itself.
Old Jun 2, 2010 | 05:14 PM
9632tl's Avatar
Radical Member
You didnt take it off when you did the manifold? Ive cleaned my egr 3 times so far. That could be a big part of the problem
Old Jun 2, 2010 | 09:45 PM
DUECEON9ER's Avatar
Sorry for anyone looking at this thread will post a D.I.Y. for anyone who needs help but I do strongly suggest removing intake manifold and cleaning everything. So I'm working on a step by step D.I.Y. just haven't had enough time to myself due to a new baby on the way. A really simple job just plan ahead to part out with two complete days to do everything right (at least that was my case). I think the reason no one posts a thread for this is because once you really get into it you forget to keep taking pics and just worry about not forgetting something or just getting it done.
Old Jun 3, 2010 | 10:05 AM
Mandy's Avatar
I took of the EGR Valve to have better access, the freeking thing is that I did not touch it. I should have cleaned the mofo. With what and how did you clean it?
Thanks.
Old Jun 3, 2010 | 10:08 AM
Mandy's Avatar
I feel for the baby coming. Good luck.
Old Jun 3, 2010 | 10:09 AM
Mandy's Avatar
Taking of the EGR is simple, as long as I know what to clean and what to clean it with. Some say brake cleaner, engine degreaser. I have both.
Old Jun 4, 2010 | 10:02 PM
Mandy's Avatar
Did the cleaning of the EGR valve help? A lot?
Old Jun 7, 2010 | 09:35 AM
Mandy's Avatar
Cleaned mine and after 40 miles, the CEL came back.
Old Jun 9, 2010 | 07:13 PM
DUECEON9ER's Avatar
How did it look when you removed the egr plate where the port is was it blocked off and caked with goop? If not you might just need to swap egr valves reason why? I cleaned my first one which I picked up at a junk yard $50 and still got the CEL back it wasn't until I swapped egr valves and thoroughly cleaned my old one that it hasn't reappeared. Don't worry I got you covered I haven't forgot. It can't be the manifold itself because mine wasn't too bad and I have 178k.
Old Jun 9, 2010 | 10:17 PM
Mandy's Avatar
The thing was the plate was not as caked with carbon. I reamed it and it looked decent. I am with you maybe it is my EGR valve. Should I start looking for a replacement valve? Thanks.
The CEL is so annoying.
Old Jun 9, 2010 | 11:15 PM
DUECEON9ER's Avatar
Mandy are you sure you reamed it all the way down to the intake manifold. Look at the hole on the intake manifold from the inside on the right bottom corner of this picture http://www.acuraautomotiveparts.org/...s=&view=normal
If you didn't ream it all the way changing the egr valve would be useless. Here's a way to check for obstruction the diaphragm on the egr valve the circular part of it that goes up and down when it actuates, when idling in the driveway is it down?, if so pull it up the car should stall or try to stall, if not you have something obstructing the egr system still. If that test clears then I would assume egr valve diaphragm not actuating properly.
Old Jun 10, 2010 | 03:26 PM
Mandy's Avatar
Let me understand:
Normally on idle valve should be down. If I lift the valve, the car should stall. If it stalls the EGR valve is working.
On idle if I pull the valve and nothing happens, the EGR is not functioning and I have a clogged EGR port.
Did I get it?
Thanks.
Old Jun 10, 2010 | 05:17 PM
DUECEON9ER's Avatar
Sorry I didn't specify which is not functioning egr valve could still be functioning but not when cruise speed is happening never mind that "if the car didn't stall that would mean you have something still obstructing the egr system, egr valve not included". The egr valve not functioning properly, in my case, I could hear it opening and closing while driving (still do) but if in some case it doesn't close all the way it will set the CEL on again like in my case.
Old Jun 11, 2010 | 09:22 AM
Mandy's Avatar
Talking
Now I am more confused...
Old Jun 11, 2010 | 08:13 PM
DUECEON9ER's Avatar
Conclusion is you probably didn't do a clean enough job of clearing out the port into the intake manifold (EGR PORT).
fifer16
1G RL (1996-2004)
Nov 22, 2024 07:07 PM
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
prbori
Sep 27, 2015 01:37 AM
