Does this sound like a bad A/C compressor???
Old Jun 28, 2011 | 04:10 PM
TLBaller's Avatar
My RPM needles goes up and down..up and down..up and down when the A/C is on and I'm at a stop light. As the needle bounces, the engine shakes along with the needle as it bounces. Not only that, my A/C is not as cold as it use to be (This is the first time in 15 yrs of owning the car that the air isn't as cold anymore..yet still cold air is blowing).
TexasHonda: Does this sound like a bad a/c compressor? If so, how much will it cost me? I'm going to guess around $1000..?? How much used? If it is that much, I am buying a new car b/c my car isn't worth that much (97 2.5TL).
If it is something else other than the a/c compressor, what is it and how much will it cost me? I'm so ready to jump the gun for the new Maxima or the Accord Coupe.
Old Jul 2, 2011 | 09:07 AM
TexasHonda's Avatar
Most likely the IACV, throttle plate, and throttle bore need a good cleaning.
Turn cooling on manual, full cold, max fan, recirculate and allow car to cool for 10-15 mins. You should get at least 35-40F pulldown (cabin air temp-center vent temp). If substantially less, cooling is down.
good luck
Old Jul 2, 2011 | 09:37 AM
ton8383's Avatar
^ 2nd that my girls galant did the same thing cleaned the iacv and it went away
Old Jul 4, 2011 | 09:40 AM
TJ2.5TL's Avatar
Check your spark plug wires too. I had a similar issue, check the plug wires and one of them had a crack in it. After I replaced them the issue was resolved
Old Jul 7, 2011 | 12:28 PM
Mandy's Avatar
98 3.2 Flamenco Black
Go for the HONDA. Scrap the Max.
Old Aug 27, 2011 | 11:23 AM
TLBaller's Avatar
reason? the thing with the two is that the honda looks great and a reliable engine and just an overall great car. The maxima just looks sexy to me! As far as engine and electronics are concern, I am taking a risk. This would be a first nissan car in the family and we have always been a honda/toyota family.
I'm just not 100% too sure about nissan/infiniti cars..
How do you clean the IACV and what is that?
Old Aug 27, 2011 | 10:34 PM
main70072's Avatar
Idle Air Control Valve, check this thread out for a picture of where it's located: https://acurazine.com/forums/showthr...+control+valve
Old May 18, 2012 | 01:48 AM
vipstar's Avatar
aka romeo da kid
From: i live north of knoxville, TN and south of Bristol, TN
Another question answered by simply looking up past posts...Thank You Acurazine and members.
Old May 24, 2012 | 10:26 AM
Natske's Avatar
The ac is an important part but not completely necessary unless you are dealing with the heat and like it cool. Most racers eliminate the ac compressor to leave room for engine to breathe. I am parting out a 1997 Acura TL 2.5 and I have a complete ac unit that I am selling if your interested. I can be reached at Naturalartworks@yahoo.com if you have any questions or need help with parts.
jdm_94-07TypeS
Oct 7, 2015 11:14 PM
Iain MacLeod
Sep 17, 2015 01:01 PM
Sep 15, 2015 06:44 PM
Skirmich
Sep 15, 2015 06:41 PM
lovic87
Sep 15, 2015 06:07 PM
