Car is starting to be very bumpy
Old Nov 27, 2009 | 12:51 AM
bwallace530's Avatar
Feels like the car starts shaking at about 60mph and under that speed she does not shake at all but over that speed she starts doing it again. I had to pull over today and check to see if my tire was not flat it was shaking that bad and all the sudden a ton of oil is coming out of her again starts leaking every once in awhile it really odd.
Old Nov 27, 2009 | 04:07 PM
Go90go's Avatar
大日本帝国
Check the wheel balance. Where's the oil coming from?
~Cheers~
Old Nov 27, 2009 | 05:54 PM
How do i check the wheel balance? I just got the car aliened at pep boys in july could it already of went out?
The oil is not leaking off of the oil filter or the oil pan if you were to look down right into the engine bay past the belts and radiator there is some bar or something like that im not sure what it is but it has oil droplets off of it here are some old pictures of the leak above the belts
Old Nov 27, 2009 | 10:33 PM
TLin401's Avatar
'13 Hyundai Sonata
That would be your water pump.
That is not good bro.
Get that thing changed immediately. If you don't and the timing belt snaps then bye bye engine.
My car use to shake at about 60 mph then I had my ball joints changed and car aligned and it went away.
Old Nov 28, 2009 | 12:30 AM
How much did it cost the get the ball joints changed and where are those at?
How is can oil be coming where my water pump is?
Old Nov 28, 2009 | 08:57 AM
TLin401's Avatar
'13 Hyundai Sonata
It cost me $450 for my ball joints to be changed and my car is be aligned.
Do you hear a clunking noise from your car?
If so then it is your ball joints.
Old Nov 28, 2009 | 02:31 PM
No i dont here a clunking noise. But my car just starts to shake alot like so much that my legs start to move. But it goes away comes back. My front bumper was loose i was at the hostipal and the parking bumps i pulled a lil to close to and ripped some rivits off so after i fixed that the bumping stopped but came back again.
Old Nov 28, 2009 | 02:32 PM
TLin401's Avatar
'13 Hyundai Sonata
Do you hear any noise coming from the front at all?
It could be your axles.
Old Nov 28, 2009 | 06:14 PM
Not really a noise at all just a lot of bumping and rattling ever once in awhile.
I here a high piched wine but it is the belts i think i cant really explain the sound i will try to get a video up if i can find out how to.
Old Nov 28, 2009 | 07:38 PM
main70072's Avatar
It could be your tires. Check them out and/or get them re-balanced if necessary.
Old Nov 28, 2009 | 09:10 PM
Yeah right now im looking on buying some off a 99 tl. But not quite sure till i go and look at them. I no the front ones are really really really low on tread so bad that if the steering wheels is cranked i will loose just about total control of the car.
saberlove
Mar 11, 2021 09:29 AM
Feb 25, 2020 09:57 AM
bearingman07936
Jan 7, 2016 03:22 PM
jordanboi
Sep 5, 2015 01:33 AM
NSolace
Sep 3, 2015 08:02 PM
