Car jolts from stop/idle
Old Feb 28, 2010 | 09:51 AM
Elli21486's Avatar
After a 45 minute ride down the highway, I noticed a serious problem. Whenever I am at complete stop and press the gas, the car won't move. In fact, if I'm on a hill, the car will go backwards, like that of a manual car. The thing is, I have an automatic transmission. The car will finally move if I press the gas to over 4000rpm. My guess is something is not making contact but since I'm not a mechanic, I have no idea. I drive a 98 Acura 2.5TL. Any ideas?
Old Feb 28, 2010 | 02:31 PM
Go90go's Avatar
大日本帝国
Your tranny is going out, but you should check the fluid level and do a drain and fill before considering replacing the transmission. Usually that solves the problem, but yours seems to be a bit worse than most members'.
~Cheers~
Old Mar 1, 2010 | 11:36 AM
Elli21486's Avatar
Just an update which is leading me to think it has something to do with the electrical system.
I parked the car for an hour or so. When I restarted the car, everything worked fine. Now recalling some other problems, a weak heater fan completely shut off before the long 45 minute drive. Also, the left turn signal was blinking twice as fast as it usually does. My guess is that when the heater fan went, it messed with some of the electrical components. I am not a mechanic, like I stated before, but I am an IT and this is like a hard reset on any other electrical devices. For the time being, I will keep the heater fan off until I can afford a replacement.
Old Mar 2, 2010 | 05:17 PM
tuanrich's Avatar
Your signal light is burn out make it blink faster.
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Feb 25, 2020 09:57 AM
Legend2TL
Motorsports News
Jan 31, 2016 09:27 AM
kuzdu
Sep 10, 2015 08:42 PM
jordanboi
Sep 5, 2015 01:33 AM
