Brake light keeps coming on....
So when I accelerate my brake light turns on for some reason.... And my mateinence thing on my cluster is red.... I've did oil change.... reset the ecu... did tranny flush.... and seafoamed... Still mateinence thing is still red... isn't suppose to be green? Idk what's causing this problem to my brake light and the mateinence.
read the owner book for reset of maitenance light- its not automatic
for the brake light- make sure all the bulbs are working and check the switch at the brake pedal
it can come loosened or fail--easy to replace $50
have you checked the fluid level in the master?
and make sure its slider inside is working--that reports the level to the sender unit
^^ all you do is get something thin and stick it in the slot next to the maintenance light, that will reset it..
- brake fluid for isn't necessarily the answer.. do you use your E brake when you park? i use mine everyday and sometimes in the morning when its cold the light will stay on for a little then go away.. no problem
mada51589
05-03-2022 08:54 PM
Skirmich
09-15-2015 06:41 PM
drewdeezy03
09-03-2015 08:04 PM
