Blower fan on 1996 3.2TL not working...any ideas?
Hi,
The blower fan for the heater/ac is not working (right when you need it of course). I checked the fuse and it's fine. It went off and then came back on for about a week, but not it's not coming back on. I can feel the heat, but now fan blowing it on any speed. I have no idea where the fan is located (my brother-in-law suggested I "hit it" under the dashboard). I'm guessing it's either an electrical thing or the fan needs to be replaced. I was wondering if any one had any ideas and maybe if anyone knew how much money I'm looking at here to fix it.
Thanks so much!
Erin
Thanks so much!
Erin
Your brother-in-law had a good suggestion. A hard thump of the blower housing (under dash on pax side near center tunnel) may cause the blower to come back on for a short time (usually till it stops where it will not restart). This confirms the carbon brushes on the motor are worn out.
A new blower is major surgery on the 3.2 and 2.5 TL's requiring discharge of AC, removal of evaporator, to access blower. I would guess this is a $400-$500 labor plus parts (OEM is pretty pricey perhaps $300). There may be some decent rebuilt blowers on ebay. I would not go used due to large labor time to replace.
Aftermarket is $200 for 4-seasons, not my favorite rebuilder. Check w/ ackits.com for a better product, or go OEM if you plan to keep the car.
good luck
good luck
