Acura 2.5TL blower motor
Hi,
I recently got a 1996 Acura 2.5TL. It has 127K miles on it. The AC/Heater fan is not blowing any air. I checked the fuse and relays, and they work good. After reading a lot on forums I think mostly Blower motor is dead. Has anybody ever replaced blower motor on this model. Is it possible to do it yourself or it has to be done at dealership or some shop.
I just hate the idea of spending another fortune on getting it done at dealership, although they havent given me a quote, but I dont think it will be inexpensive.
Can anyone guide me for this project or direct me to where I can get more information as how to do this
Thanks a lot
talligator2001
Thanks a lot
talligator2001
Use the self-diagnostic function of the Auto Climate Control to confirm a blower motor problem. Turn Key ON, and press Auto +OFF at same time. If the ON display appears in the LCD panel, blower motor is open or short circuit.
It could be something other than motor, perhaps the speed control circuit or damaged wiring, but bad motor is more likely. Have you checked for power to the fan motor connector. If power is available here, then motor is bad.
Removing the evaporator is required to remove the blower motor. This is a pretty big job for the 2.5TL. Not as bad as some US cars which require the dashboard to be removed, but does require removal of ECM, ABS control unit, and TCM.
First requirement for this job is to buy a Acura shop manual for your vehicle. I paid about $65 for mine, shortly after purchasing my 97 2.5TL. Best investment for DIY you can make.
Given the amount of work going into this repair, I would have to go w/ an OEM fan motor to insure you don't have to repeat this for a faulty remanufactured part. I had this happen on an Accord, which was easy to remove the blower module, but still a PIA to repeat a job.
good luck
good luck
Thanks TexasHonda,
I have been trying to look for the shop manual for a 96 2.5 TL, all over the net. There are lot of manuals which say service manuals but nothing that says Shop manual.
Can you tell me where did you get your manual from ? It would be really great to have one for DIY projects.
Thanks for the reply
Talligator2001
Talligator2001
i tried your diagonstic method. When I hit Auto+off together, I see OFF on display. Do you know what that says.
I am ordering the shop manual from Helm. Thanks for that information
talligator2001
talligator2001
I'm sorry, I misread the table of faults. OFF is the code for faulty blower motor or motor circuit. You should confirm that power is delivered to the motor connector before replacing the motor, given the level of effort required.
good luck
good luck
I went to the dealer to do a diagnostic. He said blower motor is bad and needs replacement. He is charging me 805$ for the whole job, including the motor. He is giving some employee discounts, since I recently purchased car from him. Labor is about 600$s approx 10 hrs. I am waiting on the shop manual to come in mail, and see how much effort and time it will take to do the job.
I just hope its not too bad and is manageable to do at home
Talligator2001
Talligator2001
TexasHonda,
I got the manual from Helm Inc. To replace blower motor, i have remove evaporator. To remove evaporator they say I need to discharge AC ( need to remove refrigrant). How can I do it. Can I do it at home or do I need to take it to some autoshop ?
Talligator2001
Talligator2001
Technically, it is illegal to discharge refrigerant to the atmosphere, but it is done frequently. R134a is pretty costly these days, so value of refrigerant might justify paying someone to recover, but I doubt it.
When refrigerant is discharged be sure to plug or cap the lines w/ something to prevent free exchange of air and moisture. This will prevent having to replace the receiver/drier.
You can reinstall the evaporator, and then take car to someone to vacuum and recharge w/ correct amount of R134a.
If you want to buy tools to do your own recharging, check following site for guidance. Learning AC repair is a skill that pays a lifetime of benefit.
AC Kits Forum
good luck
AC Kits Forum
good luck
Do I have to discharge the system. I thought in manual they mentioned that process since it further led to overhall the evaporator. But if I am not going to do anything with evaporator, do I still have to do it ?
thanks
talligator2001
thanks
talligator2001
Yes, evaporator has to be removed. It can be removed unless the connections are broken, which means system must be discharged. It doesn't look to be a terrible job, but certainly will require patience. Take your time.
good luck
good luck
Hi,
I removed the glove box on the car. I removed 3 screws holding the frame for ABS. The 4th screw which is upper left corner is not accessible to remove. I think a frame holding the Airbag is there.
I want to check the voltage across the connector for blower motor, thats why i want to get an acess to it. Is there any particular reason to remove the ECM. Since its sitting on the floor side, and everything regarding the blower motor is under dash, why would you want to remove the ECM. I know the manual says to remove it, I am just curious, how it will help in removal of blower motor etc.
Currently I am stuck on removing the 4th screw for mounting bracket of ABS, once I remove that I will be able to check the connectors. Also I am going to check the relays, tommorow to make sure they are working. If you know how remove the 4th scres(upper left hand side) please let me know.
Talligator2001
Talligator2001
I recently removed the ABS controller support frame to access on transmission control wiring. I had to use a flex extension on LH side and short extension on 1/4" ratchet on the RH side to reach the upper screws, but had not other problems.
Regarding the ECU, it may be necessary to remove to provide a removal access path. That is the case for 90-93 Accord blower module, which also has ECU mounted on the floor. You might wait to see if it's necessary. It can probably be removed at any time if necessary.
good luck
good luck
Hi,
Finally I was able to work on my car, after a long time of bad weather. I removed, ABS module, TCM all wiring harness on the passenger side. Now I stuck on the pipe cover removal. I was able to get off the 3 screws for the pipe cover. The manual shows the wire harness clips are to be removed. I was able to cut one of the zip ties, but was not able to get acess or even see the second wire harness clip. I am stuck over there, I am not able to get that pipe cover off. if you can help in anyways to direct me how to remove pipe cover it will be awesome,
talligator2001
talligator2001
Originally Posted by talligator2001
Hi,
talligator2001
talligator2001
This is where a dab of experience is worth plenty. Sorry I don't have any to give.
good luck
btw.
I was trying to get the wire clip snipped off from the pipe cover of my acura. Althouth I was not able to get acess to it, I must have hit blower motor in some way, coz I switched on the blower motor and it started working. I donot know what I did I wish I know what I did, but it did start working. Now I am trying to decide what to do, whether to go ahead and replace the motor or keep the current one. I hate to see the motor stop working after I put refrigrant back in.
talligator2001
talligator2001
btw.
talligator2001
talligator2001
I would go ahead w/ your repair.
good luck
btw.
talligator2001
talligator2001
C2CuSn07 TL
Sep 11, 2015 06:54 PM
