02 Sensor and Radio code
Old Dec 8, 2006 | 01:42 PM
Rondo's Avatar
HELP!
I bought my 3.2 TL about a year ago from a guy who took excellent care of it. Haven't had a single problem so far...but..My CEL came on a couple of days ago, the shop said it was fault code P0125 (Right 02 Sensor) and wanted $350-$450 to replace it. Anyone know of other factors that might cause the sensor to send a code? I want to eliminate other possible causes before I spend the cash to replace this thing. Also, is it a complicated affair to swap it out yourself? I'd be willing to do it if it wasn't a pain and would save me a couple hundred bucks. any advice would be useful, since I'm an idiot when it comes to this stuff.
Also, I tried to reset the CEL by pulling the 10A fuse, knowing I'd have to re-enter the radio code. I have the code from acura for my radio, but it won't accept it after numerous attempts to enter the code. Am i missing something? Does the car have to be running, or just on, or do I have to shut the radio off and back on again or something?
Old Dec 9, 2006 | 07:49 AM
TexasHonda's Avatar
I could not find a code P0125 for a 97 3.2TL. Perhaps the code was P0135, which is right O2 sensor heater circuit fault. This usuallly means the heater element in the O2 sensor has failed open and requires replacement. You can check heater element by disconnecting the O2 sensor connector and checking resistance of the heater circuit (2 black wires are the heater wires). Resistance should be 10-40 ohms.
You probably entered the code incorrectly or you have the wrong code. Reset the radio security system by pulling the fuse to the radio for 20 secs and try to enter the code again.
good luck
Old Dec 10, 2006 | 04:15 PM
Rondo's Avatar
you're right, my fat fingers messed up. it's P0135.
Old Dec 10, 2006 | 04:25 PM
CAB NY's Avatar
Tri State ViP Crew
for the radio unplug the antenna and enter the code
Old Dec 29, 2006 | 09:10 PM
dieguinone's Avatar
hi , im new to this forum , im just get an 1998 3.2 TL from a guy that sells used cars , but the car has the problem that the radio doesnt work , can you tell where do i get the radio code?
thanks
Old Dec 29, 2006 | 09:28 PM
01tl4tl's Avatar
Answer
to above posting only___
Check in the glovebox for a card with a handwritten 5 digit code written on it, also look on the edge of the glovebox and inside the fuse box covers, sometimes people write them down in the car
Otherwise- remove the radio- see thread in this forum- and get the serial number of the radio itself, take that to an acura dealer with proof you own that car- they see all the numbers match and provide you with the code no charge
Old Dec 29, 2006 | 09:51 PM
dieguinone's Avatar
01tl4tl thanks =) for your response , hope it works
Mike Pilipenko
Mar 26, 2024 09:21 PM
RobbDizzle
Oct 15, 2015 11:16 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
Skirmich
Oct 1, 2015 12:59 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
