ABS Problem
Old Dec 27, 2006 | 05:42 PM
Pradheep's Avatar
Gizmo
ABS Problem
I have an 1996 2.5 TL. Its doing great at 160K miles until last week when the ABS light started to glow randomly.
When I turn on the ignition key (not start it), the ABS light comes ON and I can hear 6 short beeps. Sometimes, the light stays on even after starting the engine and sometimes it goes off ! The braking is all good and I cannot feel any difference.
Someone told me that it might be a problem with the sensors or the brake shoes !!
Can someone please suggest what the problem might be ? Thanks in advance ! :-)
Old Dec 31, 2006 | 10:23 AM
pi1996's Avatar
you'll need to retrieve an error code that causes the ABS light to turn on, then go on from there.
Old Jan 1, 2007 | 09:56 AM
TexasHonda's Avatar
You have to short the service check connector under the glove box, turn ignition switch to ON, and ABS light will flash DTC's w/ short flashes; for instance F-F-F-F-P-F-F is flash code for 42, a LF wheel sensor fault.
The service check connector is a two wire connector, usually blue, under the glove box attached to trim. Release connector from hanger and install a short wire shorting jumper.
good luck
Mike Pilipenko
Mar 26, 2024 09:21 PM
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
