DIY: Engine Start Button
Old Apr 28, 2009 | 07:41 PM
stas2007's Avatar
Engine Start Button:
1) remove the cover around the steering wheel(there are two screws...well at least on my car)
2) remove the screw by the key mechanism:
3)you will be working with the yellow wire and the black/white wire
yellow wire is your constant power and the black/white is the power to the button when the key is second position.
you will be using crimps like these to connect your engine start button:
4)find location for your button,connect the wires and mount them
Thats it and you're done! now when you put your key in second position can start the car with the button or the key!
File Type: jpg
Old Apr 28, 2009 | 07:51 PM
stas2007's Avatar
sorry missed a part: On your engine start button there should be 2 wire connectors,thats where you'll connect the wires you bypassed in part 3.
With this mod you can use the key or the button;if you want to just use the button you ll need to cut the yellow ,black/white wire and connect it to the button.
Old Apr 28, 2009 | 08:00 PM
desired_speeds's Avatar
you covered your climate control's interior temp sensor with an ebay engine start button?
Old Apr 28, 2009 | 10:15 PM
tmnhs81's Avatar
relocate it or your climate control unit may go crazy.
Old Apr 29, 2009 | 08:44 AM
stas2007's Avatar
I relocated it next to the steering wheel; to the side bottom.
Old May 1, 2009 | 01:05 AM
KrayzieDxC's Avatar
Khmer Pride
nice diy .. bad location for engine start
Old May 4, 2009 | 01:45 PM
levelfamily's Avatar
levelfamily Ent.
nice DIY, the location for the star button is really bad, and would be nice is the car just start with button that way you can hide the button so no one can robbed your vehicle.
Old May 5, 2009 | 12:10 PM
bigwerm187's Avatar
Str8 Home built
start botton could of been in a differnt place or you could have gotten a botton that looks alot nicer.
Old May 12, 2009 | 06:29 PM
KrayzieDxC's Avatar
Khmer Pride
well i did this yesterday ,your wiring seem werid,i prob. be cautious doing it,but i did the wiring with a relay and a s2000 button and i put it next to my shifter
Old May 12, 2009 | 06:36 PM
tmnhs81's Avatar
Old May 12, 2009 | 06:43 PM
TLin401's Avatar
'13 Hyundai Sonata
x2
Old May 12, 2009 | 07:36 PM
KrayzieDxC's Avatar
Khmer Pride
here a video, sorry its dark out
Old May 12, 2009 | 07:49 PM
tmnhs81's Avatar
^Now thats dope.
Now if only it had keyless entry...oh well...
Old May 12, 2009 | 08:25 PM
TLin401's Avatar
'13 Hyundai Sonata
That is ridiculous.
Old Jun 1, 2009 | 08:13 AM
Meek32v6's Avatar
I like to whistle in my
so what happens if you accidently hit the start button again while driving?
and is there anyway to turn it off with the same button?
Old Jun 1, 2009 | 08:31 AM
Mandy's Avatar
98 3.2 Flamenco Black
Good point. Let me understand this, you have to put the key in, turn it to engine, not crank it, but instead use the engine start?
I really want to do this, too.
KrayzieDxC, you must do a DIY for us....please....how much was the S2000 switch? Where did you buy it?
Old Jun 1, 2009 | 08:33 AM
Mandy's Avatar
Originally Posted by tlin401
x2
x4!!!
Old Jun 1, 2009 | 08:34 AM
Mandy's Avatar
Pics and DIY!!!!
Old Jun 1, 2009 | 09:47 AM
akash4u's Avatar
More pics and DIY. This is my next mod.
Old Jun 1, 2009 | 01:03 PM
Mandy's Avatar
Let's go....this is great!
Old Jun 1, 2009 | 02:33 PM
TLin401's Avatar
'13 Hyundai Sonata
You did this mod?
Old Jun 1, 2009 | 03:10 PM
KrayzieDxC's Avatar
Khmer Pride
if accidently you over crank it like your trying to turn over
no, have to use the key
well it good to have the starter button incase your key cylinder is not working
Old Jun 1, 2009 | 03:11 PM
KrayzieDxC's Avatar
Khmer Pride
i'll DIY i post it when i can , plus any one can do this
Old Jun 1, 2009 | 04:20 PM
KrayzieDxC's Avatar
Khmer Pride
ENGINE START S2000 BUTTON DIY
Parts I used:
  • 1 Genuine Honda S2000 starter button. Part number 35881-S2A-911 (can be ordered from HandA-Accessories.com for $33.14 + s/h)
  • 1 SPDT (Single Pole Double Throw) Relay 30 Amps/12 Volts (you can buy this at any auto store or alarm/radio install shop. Make sure it is a SPDT 30Amp/12V relay)
  • A floppy drive power connector (will explain below why you need this. You can either yank it out of your old PC or buy it for pennies at any PC shop)
  • A crimping and wire cutter tool
  • Some 12 and 18 gauge wire
  • Some male/female Quick Connectors
  • Two ring connectors (for ground connections)
  • Electrical tape
Well if you follow pictures correctly i think you can do it without the steps..
sorry im just kinda lazy to rip it out of what i did..if you need help just ask
as for the button where to put it ..you can put it anywhere.
you can follow his steps here and use my diagram to set it up
http://yefim.com/vx/redbutton/
Old Jun 3, 2009 | 03:34 PM
stas2007's Avatar
Kraziedx nice diy!
whats the point of having a relay?mine works perfectly fine without one...
I was thinking of getting the s2000 button at first, but decided to wait till 09 tl parts become available in acura dealership so i can get the TL Engine start button
Old Jun 4, 2009 | 04:06 PM
Mandy's Avatar
This is the bomb!!!!! I will be doing this, one of these days.....thanks!!!
Old May 8, 2012 | 06:24 PM
aznevo92's Avatar
1997 Acura TL 3.2
i wanted to try this out, but idk if i should get this push to start.
Amazon Amazon
and are these diy instructions the same for any push to start.. and for my car :o
Old May 8, 2012 | 10:38 PM
TLin401's Avatar
'13 Hyundai Sonata
That button looks like trash
Get an OEM one from a Honda vehicle
Old Jul 2, 2012 | 03:49 AM
98LineCook's Avatar
i cant get to the video. so u pick a spot and drill a hole essentially?
rockyboy
Aug 4, 2024 10:35 AM
miner
3G RLX (2013+)
36
Jan 11, 2016 04:17 PM
PortlandRL
Sep 14, 2015 12:01 PM
spoiler900
Sep 10, 2015 01:06 PM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
