Vanity Light Bulb
Old Apr 30, 2006 | 02:28 AM
KaMLuNg's Avatar
Vanity Light Bulb
anyone know what size our vanity light bulbs are??? i took it out but can't find a bulb number on it anywhere...
Old Apr 30, 2006 | 08:28 AM
TexasHonda's Avatar
The specs are from my 2.5TL Acura shop manual. Manual has the vanity mirror light at 12V-2Watt, the ceiling light is 12V-8W, and the spot light is 12V-5W.
regards
Old Apr 30, 2006 | 11:57 AM
KaMLuNg's Avatar
is there a bulb number????
Old May 1, 2006 | 06:24 AM
TexasHonda's Avatar
No bulb number on any bulbs.
regards
Old May 1, 2006 | 08:02 AM
UnsanePyro's Avatar
Registered Driver
IF you go to a pep boys/auto zone (I'd try auto zone) they should be able to tell you.
Old May 1, 2006 | 11:40 AM
Go90go's Avatar
大日本帝国
I've fit a 31MM Bi-Hybrid festoon bulb into the step lights, dome, etc. The step light was the same size as the vanity light. However, I don't think that you want to see your face in hyper-white, hehe. Kinda harsh lighting.
~Cheers~
Old May 1, 2006 | 12:04 PM
Go90go's Avatar
大日本帝国
BTW, try a DE3021 or 3022 bulb. It should fit with a little squeezing.
~Cheers~
Old May 2, 2006 | 06:34 PM
TexasHonda's Avatar
Link to GE Auto Light Specs
See above link. It has all the bulbs.
good luck
Old May 2, 2006 | 06:56 PM
Go90go's Avatar
大日本帝国
Ok, double checked my bulbs, DE3021 for the vanity. It's the same as the step light, and the maplight (DE3022) would fit as well.
~Cheers~
Old May 2, 2006 | 08:54 PM
KaMLuNg's Avatar
yeah i also tried a swap today and they fit... i want to order LEDs to change the color of the mood of the interior of the car.. pics will come after i am done installing...
Old Jul 10, 2006 | 11:27 PM
Midknight_star's Avatar
4th Gear
can someone explain how to pop off the vanity light housing?? im having seriious issues my 06..
Old Jul 11, 2006 | 12:05 AM
Go90go's Avatar
大日本帝国
Wrong side of the forum if you've got an '06... But a small flat-head screwdriver should be enough to get the lense off. Try an eyeglass repair kit.
~Cheers~
Old Jul 11, 2006 | 02:14 PM
KaMLuNg's Avatar
on the 06, you actually need two flat screw drivers... one to hold the light down on the gap, and then use the other one to push the clip in to release the cover... i will try to find a pic of it...
Old Jul 11, 2006 | 02:57 PM
DJRamzy's Avatar
2003 Acura MDX
ive been wanting to do this... hyper whites on the door lights and blue on the two ceiling lights
Old Jul 11, 2006 | 07:02 PM
KaMLuNg's Avatar
i have the whole interior blue.. and superwhites in the vanities..
Old Jul 11, 2006 | 08:13 PM
Go90go's Avatar
大日本帝国
I have 10W Polargs in the doors and the dome. Don't use the map light often so I just leave that one off.
~Cheers~
BoricuaTL
Apr 8, 2016 01:08 PM
sockr1
Oct 1, 2015 01:31 AM
Greengecko
Sep 16, 2015 08:19 PM
brjones9
Sep 3, 2015 07:30 PM
Mcj270
Aug 31, 2015 04:45 PM
