Tail lights won't budge!
I'm trying to take out my tail lights and they are not moving at all. I removed the four screws on each light but they seem to be stuck to the car.
Is it possible that they were glued or something!? Anyone else come across a simmilar problem?
大日本帝国
Did you remove the nut or the bolt? You're only supposed to take off the nut. Take the side of your ratchet or a small hammer and start tapping each bolt in a cross. That should jimmy it out of there.
~Cheers~
~Cheers~
bolts are part of the lights.
Be careful when you tap the screws, they are attached to a plastic base.
I removed them by pushing the screws with my thumbs.
handsom-hustla
11-13-2015 05:04 PM
wusty23jd
09-24-2015 11:41 AM
DiamondJoeQuimby
09-10-2015 11:40 AM
