Tail light replacement?
Old Aug 1, 2004 | 01:12 PM
TEEROY's Avatar
3rd Gear
Does anyone have a clue how to replace the tail light? THere are no screws visible to remove the lense. I'm sure it's something simple.
Old Aug 1, 2004 | 02:06 PM
TLxRaCeR's Avatar
First Gen 3.2 TL
hey.. there are 4 nuts to take off.. i believe it is an 8mm nut.. might be 10mm but unlikely.. the nuts/bolts are a gold color.. hope this helps..
Old Aug 1, 2004 | 08:54 PM
TEEROY's Avatar
3rd Gear
I don't see any nuts. I have a 98. I do see a black peice of plastic covering the edge of the lens when you open the trunk. I didn't want to try and remove that and break it off. Is that where the nuts are? underneath that? or am I blind? haha
Old Aug 1, 2004 | 10:21 PM
TLxRaCeR's Avatar
First Gen 3.2 TL
are you talking about the trunk cover? there are a few plastic clips with a little button looking thing in the middle... push the center in and pull the clip off.. then you should be able to see the nuts..
Old Aug 2, 2004 | 12:45 PM
TEEROY's Avatar
3rd Gear
Ok, I'm retarded. I figured it out. thanks!!
Old Aug 3, 2004 | 11:18 AM
maverick15's Avatar
Where can I find tailights for an 96 Acura 2.5TL? The dealership gave me an estimate of $418 for one tail light replacement.
Old Aug 3, 2004 | 11:43 AM
982.5TL's Avatar
All about JDM
Try here.
http://www.acuraautomotiveparts.org/...A4AT&catcgry5=
All your acura parts needs. The taillight is listed as being $241.10. Thats just for the housing itself, assuming that u dont need a new harness, bulbs etc. Im sure that if u ordered the tails from the dealer all you would get is the housing as well. Of u need those other parts you can find them there too.
Old Aug 4, 2004 | 11:14 AM
maverick15's Avatar
Thanks...I will check it out.
Old Aug 4, 2004 | 12:41 PM
HQuakers's Avatar
giggity giggity giggity
Zach (Penguinflies) has one for sale. PM him.
mada51589
Jan 9, 2025 04:40 PM
handsom-hustla
Nov 13, 2015 05:04 PM
wusty23jd
Sep 24, 2015 11:41 AM
Ny1718
Sep 11, 2015 09:21 AM
brjones9
Sep 3, 2015 07:30 PM
