Tail light replacement?
3rd Gear
Does anyone have a clue how to replace the tail light? THere are no screws visible to remove the lense. I'm sure it's something simple.
First Gen 3.2 TL
3rd Gear
I don't see any nuts. I have a 98. I do see a black peice of plastic covering the edge of the lens when you open the trunk. I didn't want to try and remove that and break it off. Is that where the nuts are? underneath that? or am I blind? haha
First Gen 3.2 TL
are you talking about the trunk cover? there are a few plastic clips with a little button looking thing in the middle... push the center in and pull the clip off.. then you should be able to see the nuts..
All about JDM
Try here.
http://www.acuraautomotiveparts.org/...A4AT&catcgry5=
All your acura parts needs. The taillight is listed as being $241.10. Thats just for the housing itself, assuming that u dont need a new harness, bulbs etc. Im sure that if u ordered the tails from the dealer all you would get is the housing as well. Of u need those other parts you can find them there too.
mada51589
05-03-2022 08:54 PM
handsom-hustla
11-13-2015 05:04 PM
wusty23jd
09-24-2015 11:41 AM
