Squealing noise
Old Mar 29, 2014 | 10:23 PM
adventurecrv's Avatar
Squealing noise
Car will squeal - for lack of a better word - in warmer weather with the a/c on when first started. Turn the a/c off all is quiet. Once the car is warmed up all is quiet as well.
Noise comes from power steering pump side of engine.
A/C compressor is quiet and functioning. I replaced the tensioner pulley today as it had a slight looseness to it.
All accessory belts are new and adjusted correctly. Alternator is new as well.
Crankshaft pulley/harmonic balancer is new as well.
Perhaps it is the power steering pump...just strange the a/c would cause it to make a racket...
Timing belt has 50,000 km on it.
Any thoughts?
Old Mar 29, 2014 | 10:30 PM
dcolucci7's Avatar
I had this problem on another car. Turned out to be the AC clutch bearing. Not sure how much they are for the acuras.
Old Mar 29, 2014 | 10:55 PM
I'll have to check that out!
OEM $177 from Delray...
Old Mar 30, 2014 | 04:55 PM
Well I headed over to Harbour Freight and splurged on a Mechanic's Stethoscope. $2.99 on offer.
Of all things it is the fan motor going. The fan only kicks in when the a/c turns on, hence no noise with the a/c off.
The Stethoscope is a really handy tool that is for sure.
$192 from Delray for a new one...ouch...I will look elsewhere...
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
