Reverse Glow Gauges
Attorney- Will Sue 4 Food
it is easy, search for the post that setp by steps this. Main thing to look out for is removing the part of dash assembly with the vents, the area around the vents breaks easily if too rough
Quality Over Quantity
here's the post with the instructions gauge instructions , it's the 11th post posted by TL-Ridaz96.
Well, i decided to install my reverse glow gauges today! And i'm stuck! I got the dash cluster out after fighting with it but managed to do so without breaking anything. With the cluster out and the clear plastic shield out to the way, i can't figure out how to remove the needle so i can replace the gauges. I don't want to pull too hard and break the darn thing. Is there a speciel way to do this? I know that i should be delicate since it could throw the needle readings off a bit.
BTW, i'm also documenting the process with prictures so others will have an easier time doing this. Other problems that i'll run into is where to splice the power to the new gauges into. I'm not going to use the fader and the colour switch that cam with the gauges, i want to use the factory fader and have the gauges remain blue, no need to switch to green.
The lsat two things shouldn't be too hard to do, but i still need to figure out how to get these things on first!!! If any of you read this....please help me out since my vehicle is not drivable until i get it done. I don't want to assemble everything and do it all again next weekend.
Thanks!
Thanks!
fight ninja! ya!
I've heard that the needles come off. But I've also heard that they don't. (odd, I know) I would have to suggest that you VERY carefully slide the needles through the hole in the center of the new guage.
There also have been problems with the needle getting stuck at a certain degree, or even not moving at all. This can be corrected with a fine sandpaper to take a mm or 2 from the guage face hole.
Is there a reason why i can't edit my previous post? Anyways, I have managed to install the gauges over top of the original, found this out by looking at the second gen how to. I did a little bit of trimming so that the wires run out the back of the cluster.
I ran into trouble when i was planning to use the factory dimmer instead of the one that the new gauges were attached to. Insulted my dad and he did some test with a multi meter and came to the conclusion that i couldn't use the factory dimmer becuase of a component that was housed within the dimmer wouldn't allow it to work properly. That idea was scrapped.
My main problem now is that i don't know where to draw the power from for the gauges. I looked in the fuse panel under the dash and there isn't a spot where i can get power. There is spots but nothing compatable to turn on the dash when the front lights are on. I don't want the gauges to light up constantly, only when the are supposed to, when the lights are on.
Any suggestions??? There's gotta be someone who has a first gen that has done this. Time's running out before i reassemble everything.
All about JDM
I installed mine no problem. Slid them over the needles and didnt have to trim anything. I ran power to the gauges from the power line used for the clock. I just spliced them together. Works like a champ!
Battery:Ignition:Light:Ground
Abviously i would use the ground for the black wire. Now would i use the ignition or the light terminal? Would i be right if i said the light terminal? Since the clock would actually dim when i turn on the headlights hence tell the gauges to light up?
I'm almost done....all i have left is to wire the power and reassemble the trim. Everything else is in place.
It's all done. I have documented the process but haven't had a chance to do a decent "How-To" Guide. Feel free to ask ?'s and i'll try to answer it from my experience.
Did you end up tapping into the clock for you gauges to work? Did you use the ground and lights location on the clock wires for it to work? Do they stay on constantly or just when the lights are on? I tried to get it connected to the parking light combo switch( red black ground and red green power) but all I got was the 'lights on' chime to come on and no juice to the indiglos. I then tapped the light wire (solid red with 2 grey spots) and they came on but with the keys not in and the light switch off so they were constantly on. So till I get back home I dunno what way to get them to work. When I do get back I"m going to Acura to see a friend to check it out. thanks
Originally Posted by tyger
What combination of from the clock did you use? I noticed that they ar labeled on the clock assembly, from left to right looking at the terminals:
Is that how it works, if you attach the power wire to the clock "light terminal?" I'm not sure what that is, is that a wire in the dash? That would be sweet, i definitely want the gauges to only turn on if the headlights are on...I have some Gauges on order as well, little nervous about the install with all the stuff going back and forth on the boards! Oh well, it will be an experience thats for sure.
All about JDM
I like how the gauges shine when the parking lights are on. I did the fog light wiring splice thing to where my fogs come on with the parking lights, and i drive with them on 24/7, parking lights with fogs during the day, and then headlights of course during night driving. Honestly, during the day you cant even see that the guages are lit up. Doesnt bother me at all.
Got mine hooked up with the clock. It works just fine and comes on with the parking and headlights. I like the look of the white face but wish I could have found a set with white faces but with silver numbers and markings instead of the blue. but I like the look. thanks for help.
2007 6SMT Type-S
can anyone put together a "How To For Dumbies" on this thread??? I want to install some myself but with all the confusion and pieces of info through out the thread it's hard to keep it all straight.
[img] 'http://www.cardomain.com/member_pages/show_image.pl?fg=000000&bg=FFFFFF&migration=1&imag e=http://memimage.cardomain.net/member_images/6/web/618000-618999/618268_24_full.jpg', 575, 461 [/img]
2007 6SMT Type-S
Hey boarder, thanks for the reply, but can you fix your link? Thanks dude
Sorry about that, Im at work now so I cant add anything, but if you check out my cardomain website (link in my signature) there are some pictures on there referring to the guage install...
