Replacement Engine?
Old Jul 29, 2004 | 11:58 AM
harris-golf's Avatar
Replacement Engine?
I am thinking about purchasing a 1996 3.2 TL, but the problem is that it needs an engine replacment. First question - is it worth replacing or just consider the car junk? Does anyone know where to get a good quality engine in the Kansas City area? Any guesses on the cost for engine and install?
Thanks.
Old Jul 29, 2004 | 12:06 PM
LDH's Avatar
LDH
I
well first off how much is the shell of the car going to cost? If it is cheap, then you can go find a new engine or part it out for us . Since it is a 3.2 you could put in a stock motor or a type II legend engine. Since your engines already out you could try the 6 spd manual swap
Old Jul 29, 2004 | 12:25 PM
The shell of the car is around $2500 delivered. Engines I have priced are $1200 for used with 50k. Installation has been quoted to me at $1500. It looks like I would be in the $5200 to $5500 range for the total cost. Any more suggestions.
Old Jul 29, 2004 | 12:51 PM
Wampum's Avatar
doesn't sound like a bad deal if you have that kind of cash to front. be sure that all of your work has a warranty and the parts are from a reliable source
Old Jul 29, 2004 | 02:34 PM
Ken1997TL's Avatar
Exactly, if done properly this could be an inexpensive way to get a good car
Old Jul 29, 2004 | 04:04 PM
demons rage's Avatar
i say do it, but be different. drop in the legend engine /w the 6 spd tranny and show us the first 6spd first gen tl
Old Jul 29, 2004 | 04:29 PM
Ken1997TL's Avatar
I've been working on it with my uncle but we'll have to do a custom center console job. (Time to put more wood in the car)
Old Jul 30, 2004 | 06:03 PM
Cornflake's Avatar
Reppin' the T-Dot!!
I SOOOO want to do this BADLY. If I wasn't saving for a house right now this would already be done\....once the house is purchased and I get truck fro the winter, I'll be putting the TL up on blocks and picking up a legend 6 spd to drop in.....along with maybe an RL block....Guy did it on www.acure-legend.com in a legend, no reason why it shouldn't work on the TL.....WOULD BE SICK!!!!
Old Jul 30, 2004 | 08:11 PM
Ken1997TL's Avatar
Yup, DV8 I think is his name on the Legend forums.
To my knowledge, no one has done a manual tranny swap to a 1st generation TL.
Old Jul 31, 2004 | 08:28 PM
Cornflake's Avatar
Reppin' the T-Dot!!
I think the easiest way to do the console would just be to get an aftermarket boot that's big enough to reach under and attach it from underneath, should look pretty clean.
BKSleeper
Oct 7, 2015 10:20 AM
Aging-Hacker
Oct 5, 2015 11:44 AM
wusty23jd
Sep 24, 2015 11:41 AM
iCrap
Sep 11, 2015 06:21 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
