Problems Starting
Old Jul 12, 2001 | 04:52 PM
unx979's Avatar
Problems Starting
i've been having problems starting my car everyday. it ususally doesn't start on the first crank, but it works on the second one. any suggestions as to why it does this? someone suggested that it's the fuel pump and that there might be something wrong or a leak in the hoses. i guess i'll get that checked out the next time i go into the dealership for maintinance. I just bought new NGK wires and hopefully they'll help a little bit. gosh this summer is bad for my car, so many things going wrong.
Old Jul 12, 2001 | 06:12 PM
i have the same thing happen to me once in awahile. i noticed irt just after i had the cold air intake installed..
Old Jul 13, 2001 | 12:00 AM
dbox's Avatar
whoXwanXsum
same sheat happen 2 me, i replaced ma starter and problem was solved. take it 2 tha dealer, they will let u kno
Old Jul 13, 2001 | 12:11 AM
unx979's Avatar
knowing the dealers they're just going to make me replace everything. but i'll slowly replace my ignition system with an aftermarket one so this way i can fix the problem and maybe get some performance out of it for the same price.
Old Sep 12, 2001 | 02:00 PM
Guest
Guest
Posts: n/a
re: Problems Starting
My 96 2.5tl will sometimes turn over for 5 seconds or so before starting. It only happens once in a while and there is no pattern to it. The dealer says this is common for my engine. Has anyone experienced this?
Old Sep 12, 2001 | 06:14 PM
96TL2.5's Avatar
hey what a relief.. i just started having that problem too .. i thought it was just me... i think its a good idea to take it to the dealership.. if anything at least you will know what the problem is...
Old Sep 13, 2001 | 09:38 AM
TLBaller's Avatar
this happened to me before. one time it was choking for awhile before it started and another time, it just didn't start at all! when that happened, i got someone to jump me and the problem was solved. I just recently bought a whole new battery but i plan on returning it since im getting some performance battery (optima) since im getting my system put in soon.
Old Sep 13, 2001 | 09:56 PM
962.5tl's Avatar
i had same problem i got a tune up and they replaced the "distributor cap" and i havent had problem since
Old Sep 14, 2001 | 12:14 AM
TLover8888's Avatar
is optima the battery that is red (i think) and has a 6 spiral-looking design to it? if it is, i just read in consumer reports that it is actually not that great of a battery. it actually performed below average as compared to other similar type batteries.
Old Sep 14, 2001 | 01:40 AM
Dirty intake mainifold, throttle body and incorrect spark plug gap will cause hard starting problem, first think to check is the spark plug gap, core on the plug will worn out in time.
Old Sep 15, 2001 | 12:51 AM
Mr3.2TL's Avatar
Same thing happens to me. The engine will crank 4 or 5 times. After second attempt it will start on first crank. This is with a brand new dealer installed starter.
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
obert
Dec 14, 2015 11:36 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
jordanboi
Sep 5, 2015 01:33 AM
NSolace
Sep 3, 2015 08:02 PM
