Power Trunk Realese
Old Aug 12, 2007 | 03:36 PM
deadsetonlivin's Avatar
Power Trunk Realese
Anyone have one installed? I'm thinking about getting one.Tips?
Old Aug 12, 2007 | 06:24 PM
KaMLuNg's Avatar
its called a trunk release solenoid... i have it and it is linked to my car alarm... since my remote has a button... i love it...
Old Aug 12, 2007 | 06:37 PM
Go90go's Avatar
大日本帝国
I have nothing in my trunk. Just some little leaves from when I had it open and people were staring at how much room there was since nothing was in there.
~Cheers~
Old Aug 12, 2007 | 09:02 PM
96teeluxury's Avatar
Tri State ViP Crew
sounds like a cool idea when i get my viper installed
Old Aug 12, 2007 | 09:28 PM
AJ3's Avatar
AJ3
3.2 Infatuated
That would be schweet.. its probably a good idea to get new trunk strut assemblies(or are they springs?) if they are a little worn, just to get that auto trunk lift feature when you open it, because the solenoid will only "pop it open" but not lift it...right Kamlung?
Old Aug 12, 2007 | 09:56 PM
KaMLuNg's Avatar
well when it pops it, depending how heavy your trunk lid is (whether or not you have a spoiler)... a OEM lid without anything on/in it can possibly open by itself... if you release the trunk from inside the car does it open by itself??? this would be a good test???
as for me, i have so much filler and sound deadening material on my trunk lid, it is ridiculous... but yes they do sell those upgraded springs to help them open easier...
Old Aug 12, 2007 | 10:05 PM
TLin401's Avatar
'13 Hyundai Sonata
I'm def. going to take this into consideration for when I get my alarm installed
Old Aug 12, 2007 | 11:11 PM
Yea my autopage has the button and imput i just gotta figure out how to install one.
Old Aug 12, 2007 | 11:26 PM
Go90go's Avatar
大日本帝国
I was at the West Coast Acura Legend meet yesterday and one guy had the heavy duty sticks in there to offset the weight of the wing.
~Cheers~
Old Aug 13, 2007 | 12:03 PM
KaMLuNg's Avatar
all u need is a relay... since the solenoid usually receives a positive signal but the alarm usually outputs negative for the Aux option... but check your alarm to make sure...
Old Aug 13, 2007 | 04:17 PM
but i'll still need the solenoid to power the realease tho right.
Old Aug 14, 2007 | 10:47 PM
Ysidro's Avatar
The solenoid is pretty cheap. I got mine at circuit city for like $20 at the back where they install car radios. You have to go there and ask for it.
It can be added to any alarm that has a free open channel.
The way you set it up, on the alarm brain, there should be a channel signal wire that gives off either a positive or negative volt when the button is pressed.
These wires give off low voltage so you cant use it to power the solenoid else it can damage the brain itself. Its meant to activate a relay. The relay will supply power to the solenoid, turning it on and off.
Also, you might need to convert the polarity depending on the polarity of the channel signal wire, and put fuse.
To help make the hood pop up better when I activate the solenoid, I JB weld a short spring under the trunk andclean the rubber seal once in a while.
goodluck.
mlody
Dec 4, 2019 02:11 PM
Jul 16, 2017 07:33 AM
jmaxima03
Sep 27, 2015 10:22 AM
justin.w13.walker
Sep 22, 2015 02:21 PM
