Power Steering Fluid?
Old Dec 17, 2005 | 12:19 AM
gokartmozart's Avatar
Quick question. What is Acura's policy on power steering fluid? Do you have to change it? Flush it? Or just leace it alone?
Thanks!
Old Dec 17, 2005 | 09:06 PM
Altitude's Avatar
Mine makes noise on a cold (-3C) startup therefore Im having mine flushed with varsol and adding new fluid on tuesday. Hope it helps....
Old Dec 18, 2005 | 08:47 AM
TexasHonda's Avatar
Only comment in maintenance schedule (95-98 2.5 TL manual) is to check fluids condition and replace as indicated.
PS fluid can be changed relatively easy, however cleaning the system is more difficult as there is a filter element in the reservoir that will cause new fluid to become quickly same color as old fluid. I would be cautious about introducing varsol (a powerful solvent) into the PS system. Varsol could affect the performance of seals and cause leaks. You can flush the system by removing the return hose from the reservoir, attaching a drain line to return hose, and catching old fluid in a pan. Crank engine and add new PS fluid as old fluid drains to maintain reservoir level. Stop when new fluid appears at return line.
good luck
Old Dec 18, 2005 | 09:17 AM
Altitude's Avatar
You think the Varsol may disolve the seals? Then maybe I wont use that.
IS there a way to replace of clean the filter element??
Old Dec 18, 2005 | 10:50 AM
TexasHonda's Avatar
I don't think it can be removed, but you can disconnect the reservoir and clean filter in place w/ mineral spirits, a much milder solvent. Also dry w/ compressed air and put under a hot lamp for 2-3 hours to evaporate all traces of solvent in the filter.
Note, I don't know that varsol w/ dissolve or damage the seals in PS system, but it's not worth the risk to simply clean the fluid.
good luck
Old Dec 18, 2005 | 07:07 PM
Altitude's Avatar
Ill just flush out the old with the new. any idea on the capacity of a 3.2s P/S system?
Is there REALLY a big difference with honda fluid instead of generic brands.
In the Jeeps we offroad with we use ATF fluid, but a P/S pump for a jeep is 20 bucks a TL's is quite a bit more.
Old Dec 19, 2005 | 07:01 AM
TexasHonda's Avatar
There are brands of aftermarket PS fluid that claim compatibility w/ Honda's specs, but are not recognized by Honda as replacements. I've used Bardahl brand in my Accords w/o problems. I haven't added any PS fluid to my 2.5TL as yet.
The capacity of 2.5TL PS system is 1.4 US qts. I imagine the 3.2TL is similar.
good luck
Old Dec 19, 2005 | 09:07 PM
Altitude's Avatar
Thanks TexasHonda
TL-Rocket
Apr 29, 2023 02:33 AM
Yikes
May 3, 2021 04:29 PM
mike from annapolis
May 7, 2017 08:21 PM
nash3222
Sep 10, 2015 09:46 PM
