need help guys...
Old Dec 19, 2005 | 04:31 PM
demons rage's Avatar
need help guys...
I had a CEL come on last week, P0401, and i looked it up online and cleaning the EGR was supposed to fix it... so i did... adn that shit is hella dirty... But the CEL is still on... could it be something else by any chance?
Old Dec 19, 2005 | 05:00 PM
meazz1's Avatar
After I cleaned the EGR passage way, light stayed on and I had to reset the code with the scanner for it to go away.
Old Dec 19, 2005 | 05:43 PM
Ken1997TL's Avatar
Unplug the battery and let the system restart itself.
Old Dec 19, 2005 | 06:15 PM
TexasHonda's Avatar
Did you clean the EGR manifold downstream of the EGR valve? This can be the source of the problem.
If you bypass the EGR solenoid vacuum switching valve and bring vacuum directly to the EGR, it should open w/ engine at idle. This should cause the engine to stumble and perhaps stop due to overleaning the air/fuel mixture. If nothing happens, the EGR passages downstream from the EGR valve are blocked and must be cleaned.
good luck
Old Dec 21, 2005 | 01:41 AM
whooo thanks for the unplugging battery suggestions... never would have though of that lol... i probably wouldve been more prone to taking apart the whole engine to fix it isntead
MilanoRedDashR
38
Sep 28, 2019 09:13 AM
spooky3ce
Dating & Relationships
26
May 1, 2005 10:34 PM
is300eater
Mar 24, 2005 12:31 AM
allmotor_2000
Jul 4, 2004 12:13 AM
bent09
39
Jan 26, 2004 02:32 PM
