need help guys...
Received 2,329 Likes
Originally Posted by meazz1
After I cleaned the EGR passage way, light stayed on and I had to reset the code with the scanner for it to go away.
Unplug the battery and let the system restart itself.
Did you clean the EGR manifold downstream of the EGR valve? This can be the source of the problem.
If you bypass the EGR solenoid vacuum switching valve and bring vacuum directly to the EGR, it should open w/ engine at idle. This should cause the engine to stumble and perhaps stop due to overleaning the air/fuel mixture. If nothing happens, the EGR passages downstream from the EGR valve are blocked and must be cleaned.
good luck
good luck
MilanoRedDashR
38
09-28-2019 09:13 AM
