Inline Five Cylinder OWNAGE
Old Jul 9, 2008 | 08:22 PM
Ken1997TL's Avatar
https://acurazine.com/forums/showthr...5&page=1&pp=40
Enjoy! Especially you 2.5 TL guys
Old Jul 9, 2008 | 08:42 PM
KrayzieDxC's Avatar
Khmer Pride
haha he got owned and cant reply to his own post
Old Jul 9, 2008 | 09:15 PM
erick3's Avatar
ouch lol
Old Jul 10, 2008 | 08:44 AM
meazz1's Avatar
Lol!!!!
Old Jul 10, 2008 | 09:39 AM
Blazing GT's Avatar
and he was so confident and thought the sales guy was a fool
Old Jul 10, 2008 | 11:04 AM
vincethe1's Avatar
3.2 VTEC
well, you gotta admit the sales guy was also pretty lost, he said it gets about the same mielage as the 4cyl. what 4cyl? the other option is a 6cyl.
and he also claimed it's a v5....which is obvious he didn't know shit lol
Old Jul 10, 2008 | 02:14 PM
5cylinder's Avatar
Saving Old Cars
Good Times.
I dropped off my vigor at Acura today for service and told him to use the 2.5 TL specifications for the motor (swapped).
first he thought it was a 6 cylinder, then he figured out it was five and though i swapped a 5 cylinder into a I4 car...
it took a lot of patience on my part.
Old Jul 10, 2008 | 02:49 PM
vincethe1's Avatar
3.2 VTEC
Originally Posted by 5cylinder
Good Times.
what's the difference between the vigor I5 and the TL I5? was it really worth a swap? or was it for other reasons...as far as i see they have the same specifications (same power/tq numbers, same dispalacement, both 20valve sohc, ect.)
Old Jul 10, 2008 | 06:58 PM
Go90go's Avatar
大日本帝国
^ Just a newer motor.
~Cheers~
Old Jul 10, 2008 | 07:31 PM
KaMLuNg's Avatar
but if you mate the 5spd to the vigor motor OBDI, i figure your can drop this into the TL and have a MT???
Old Jul 11, 2008 | 04:15 AM
vincethe1's Avatar
3.2 VTEC
that's fu**** up, why did they not have a manual in the 96-98 TL?
Old Jul 11, 2008 | 08:06 AM
KaMLuNg's Avatar
same reason they didn't have a MT in the 99-03TL??? cuz Acura goofed...
Old Jul 11, 2008 | 01:04 PM
5cylinder's Avatar
Saving Old Cars
2.5TL had slightly higher compression, although i swapped because i bought the vigor with a dead motor and used the G25A4 block. I like the EGR system from the vigor (G25A1) better so i used the intake manifold from the A1
Old Jul 17, 2008 | 02:51 AM
TippindaGrape's Avatar
lol thats classic. I went threw a few those when i was lookin around for a car. I dont know much about cars mechanically but i know enough to know when dumb asses like those dont know wth there talkin about
Old Jul 18, 2008 | 11:31 AM
Ken1997TL's Avatar
Good Times.
Which Acura dealer was this??
Old Jul 18, 2008 | 11:13 PM
lol the dealership up here in colorado inst to bad. from what i understand. but most past experince with dealships leads me to blieave they are nothing more then bullshit lmao
Old Jul 22, 2008 | 03:26 PM
CitizenPete's Avatar
It is a bit strange owning a 5 cylinder.
My first car was a V-7 Pontiac Catalina with about 90K miles. One owner who "always got it serviced at the same shop for the life of the car". The rear plug on the Drivers side was behind a compressor, so it was NEVER changed - the cylinder had no compression at all (just along for the ride) so it was a 7 cylinder. I abandoned that car at a shop in Ocean City Maryland when the timing belt broke.
Old Jul 23, 2008 | 07:25 AM
vincethe1's Avatar
3.2 VTEC
Hmm, it shudn't be too bad at 90k with original plugs. I think our TLs are 105k miles no tuneup, so that would mean 105k on the original plugs. Mabe those older cars had to get em done more often, but even if so, why would he cylinder have no compression because of the spark plug not working?? And how would you know it has no compression? you have to remove the spark plug and put your finger or a compression gague to find out.
if the fault was only the spark plug then it should run if you replace it.
Also correct me if i'm wrong but isn't that V8 (or V7) with pushrods? I wud think so because it's an american v8, and if so then it does not have a timing belt.
Old Jul 24, 2008 | 08:07 AM
Yeah... A mechanical engineer I worked with was a weekend mechanic (charged for oil changes, tune-ups etc.), so we tuned up the Catalina and found out that you couldn't get to the rear spark plug, so we pulled the AC compressor (I think it was the AC compressor) and got to it.
The plug tip was completely gone and when he put a pressure gauge on the cylinder - for some reason (the rings were worn?) there was no compression in that cylinder . So essentially it was a V-7. Probably not very fuel efficient.
SidhuSaaB
May 30, 2020 12:40 AM
mlody
Dec 4, 2019 02:11 PM
Jul 16, 2017 07:33 AM
joflewbyu2
Oct 8, 2015 11:16 AM
