How I replace fog light bulbs?
Sorry about disturbing you guy with my noob question. Although I did try to replace the fog light bulbs, but I could not make it.
Here are some pics which I hope can make you convenient to show me which sccrew I should take out.
![](http://i189.photobucket.com/albums/z189/dethuong_x0x/DSC00700.jpg)
![](http://i189.photobucket.com/albums/z189/dethuong_x0x/DSC00702.jpg)
Thanks in advance!
Thanks in advance!
'13 Hyundai Sonata
First of all you don't need to unscrew any of those screws. Second there is a rubber seal on the backside of the light that holds the fog light. Once you remove the rubber seal after you disconnect the light thrlere is a metal "trap" that holds the bulb in spot. If you have a H3c bulb then it is plug n play and reverse the process. If you don't have the bulb then you need to do the H3c to H3 bulb DIY. Good luck.
'13 Hyundai Sonata
Those bulbs are easy to replace. There is a little opening that gives you access to the bulb. Once you find it you have to twist and it will come out. The bulbs that you need are 194.
![what](https://acurazine.com/forums/images/smilies/what.gif)
'13 Hyundai Sonata
There is a mod that you can do for this also. As soon as I figured out how to do this mod I fell in love with it. Here is the link: https://acurazine.com/forums/1g-tl-performance-parts-modifications-121/diy-parking-lights-fog-lights-522181/
There is a mod that you can do for this also. As soon as I figured out how to do this mod I fell in love with it. Here is the link: https://acurazine.com/forums/showthread.php?t=522181
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
