Replaced the motor
Some questions about your idle...
every honda motor i have swapped starts its cold idle around 2100rpm.
when i swapped the G25 if i let it warm up it wouldnt lope or bounce, but if i got right to driving it would act up.
Is it loping/bouncing at all times or only when cold?
Also, since you have a CEL you could have broken a knock sensor, that too has a affect on the idle.
I would diagnose your Check Engine Light first and then move to the idle problem.
Also did you save some parts from the old motor before you tossed it out?
Sep 15, 2015 06:44 PM
