Help maintenance required light is on
Old Dec 7, 2006 | 02:45 PM
SRK85's Avatar
intelligentsia
From: Land of cheap vodka, hot girls, and great nightlife
Exclamation Help maintenance required light is on
My maintenance light changed yellow. Is my car alrite to drive? Can I drive a 60mile drive and not have it break-down. I never had this happen before and I couldnt find any info in the owner's manual. Is this a serious problem or just take care if when you can. Which will be Tuesday.
Old Dec 7, 2006 | 03:48 PM
dl2000's Avatar
maint light....
your maintenance light is just an indicator for regular service. It can easily be reset by inserting your key into the console back to green again. It turns yellow every 3-4000 miles letting you know an oil change is due and a check up on all your fluids.
You will be alright, your car will not catch on fire.
Old Dec 7, 2006 | 04:18 PM
Go90go's Avatar
大日本帝国
BTW, it's not a light, just a spinner that goes by mileage. I was driving spiritedly with that indicator on red, .
~Cheers~
Old Dec 8, 2006 | 03:13 PM
SRK85's Avatar
intelligentsia
Thanks for the info its getting serviced friday. I think I messed up the alignment by going up a curb. I never had the indicator thing change color for the 3 years I had the car. So I was surprised to see that happen.
Old Dec 8, 2006 | 03:27 PM
dl2000's Avatar
3 YEARS THE INDICATOR STAYED GREEN?? It should change every few thousand miles....maybe stuck. Just do the reg maint at each interval and forget about the indicator.
Old Dec 8, 2006 | 08:28 PM
Go90go's Avatar
大日本帝国
It changes with a scheduled maintenance mileage i.e., 30K, 60K, 90K, etc. Mine came at about 220K so someone must've reset it before.
~Cheers~
Old Dec 8, 2006 | 11:33 PM
SRK85's Avatar
intelligentsia
I guess I always got my cat maintenanced before it changed color. I dunno.
Old Dec 9, 2006 | 02:56 AM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
The inidcator found in old Honda's is not smart. It's just a mileage thing. It doesn't know if you've got serviced, that's why you are required to reset it with the key. It should change first to yellow, then to red when an OIL CHANGE is due. It is only good for oil changes, just like the Maintenance Req'd light in the new Honda cars. It will change color on a mileage-basis, regularly, unless it is broken.
Some of you guy's have to make things much more complex than they really are.
Old Dec 9, 2006 | 08:08 PM
Go90go's Avatar
大日本帝国
I don't see any complicated posts.
~Cheers~
P.S. Never in any of my Hondas did it turn red every 3000 miles.
Old Dec 10, 2006 | 02:56 AM
03CoupeV6's Avatar
That would be because Hondas don't need oil changes in 3000 mile intervals. Even my old 1993 Accord only needed it every 5,000... and the maintenance required indicator turned yellow at 4,000 since last reset, and red at 5,000. Simple system.
BTW - when I made a comment about the complexity of things, what I really meant was that people jump in and guess at it, going as far as thinking that maybe the indicator knows the oil has been changed - as if it has an oil life monitor.
Old Dec 13, 2006 | 05:46 PM
98_2.5_TL's Avatar
TL Enthusiast
Dummy light. light for dummies
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
PortlandRL
Sep 14, 2015 12:01 PM
datadr
Sep 12, 2015 09:12 PM
ahsm
Sep 9, 2015 08:35 AM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
