Hazards Stopped Working
Old Mar 7, 2002 | 09:21 PM
riches's Avatar
I own a 1996 2.5 TL. Today my hazard stopped working. Left and right indicators suddenly stopped working. I am not sure what the problem is. All fuses are good. Has anyone ever had this problem?
Thanks for your help.
Old Mar 7, 2002 | 09:24 PM
962.5tl's Avatar
first did you do anything to the wiring of the car to make this happen
has anyone worked on your car recently
did you check both fuse boxes (underhood and in driver kick panel)
not that much else that could just go like that maybe a wire got disconnected
Old Mar 7, 2002 | 09:32 PM
riches's Avatar
Thanks for the reply. No rewireing was done. Where exactly is the driver kick panel? Driver side close to the break pedal?
Old Mar 7, 2002 | 09:43 PM
962.5tl's Avatar
to the left or your dead pedal(thing where you rest your foot) is a little panel you have to turn a little tab and then pull it off it list everyting on there and list where the spare fuses are
Old Mar 7, 2002 | 10:08 PM
riches's Avatar
Found it. Thanks. No dice. I hope this is not an electrical problem.
Old Mar 7, 2002 | 11:37 PM
Din's Avatar
Din
Check the flasher relay. Not sure where it would be though. Im thinking in the fuse box by the kick panel. heres a pic its should be the lil black box looking thing
Old Mar 8, 2002 | 08:52 AM
riches's Avatar
I just noticed not only dont the indicator come on but the clicking noise you hear when you turn on your indicator isnt working. Might be the relay right? Because if the fuse was blown you would here the clicking noise but no flashing ligts.
Old Mar 8, 2002 | 01:48 PM
Din's Avatar
Din
If you dont hear the clicking noise I would look for the flasher relay.
Old Mar 11, 2002 | 11:47 PM
KaMLuNg's Avatar
yeah its the relay... cost me 90 bucks to fix once.. none of the signals work... so check that out...
Old Mar 12, 2002 | 12:39 AM
riches's Avatar
You wont believe this guys. I took the car to the electrician. Waited almost 2 hours until he finally looks at the car. He did something under the steering wheel, blew the horn then told me I was all set. I ended up paying him 20 bills. When I ask what the problem was he refused to tell me. He said the problem would now reoccur. What do you guys think it was?
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
SilverJ
1/2G MDX (2001-2013)
Sep 21, 2015 02:40 PM
acurajj
Sep 19, 2015 03:47 PM
theinsvnity
Sep 10, 2015 10:22 PM
