Ghost Emergency brake light
2.5 TL ART
Guys, I have a problem,
Starting this week my emergency brake light has been coming on , on it's own, without use of the actual brake, merely while I'm driving down the road.
Now not to drone on this small annoyance, but due to the e-brake light being on, while in motion, my ABS malfunction light also comes on.
Now what I'd like to know, is this a problem that needs to be fixed quickly, or like a said, is it just a small annoyance?
After having said that, does anyone know a simple fix for this problem?
Or would anyone know the cause to this problem, incase i need to figure it out myself?
I have a '96 TL, besides this everything is running tip top shape...
,Thanks
,Thanks
TL = Tranny Lubrication
Any time the ABS and Brake light come on it's something you need to get checked. It's annoying that they do come on but's it on for a reason.
I agree with Mr.Steve 1st check your brake fluid level.
You might also want to see how much brake pad is left on your rear brakes. I had the same thing, but only when I accelerated. As soon as I got some new rear pads, the problem was solved.
All about JDM
Reppin' the T-Dot!!
1 Post
Have the same problem. That light, as was stated earlier, serves two purposes, e-brake and brake fluid level. Mine kept coming on, had a problem with a leaking caliper. Fixed that, topped everything off and still got the light time to time. Turns out my floater in the Brake booster keeps getting stuck now! FLuid level is fine, take the cap off the reservoir and put it back and everything is good. Going to get a new cap once the motor swap is done.
Reppin' the T-Dot!!
1 Post
Originally Posted by shawn744
so the brake light DO come on when your pads are low?....i've never gotten to the bottom of that.....
2.5 TL ART
Thanks guys appreciate all the help, sorry it was so simple, I thought I had a prob with my ABS or something which would be fauked up!
I topped off my break fluid which was slightly above the MIN line,
everything's fine, E-brake light hasn't come back on, hence the ABS malfunction light hasn't come back on.
problem solved.
THanks
problem solved.
THanks
rockyboy
08-04-2024 10:35 AM
mada51589
05-03-2022 08:54 PM
