Front rotor removal problem
Old May 16, 2010 | 08:32 PM
Mandy's Avatar
98 3.2 Flamenco Black
I was going to replace the pads and wanted to get the rotors turned.
However, I could not remove the 2 screws holding the rotor in. PB blaster and all but still just do not want to unscrew.
Need help and suggestions.
Old May 16, 2010 | 11:13 PM
TLin401's Avatar
'13 Hyundai Sonata
Impact screwdriver
DUECEON9ER's Avatar
Try using different screwdriver head sizes and sounds crazy but try tightening it and then loosening it just might work.
Old May 16, 2010 | 11:14 PM
tmnhs81's Avatar
Spray some WD40 and tap on the center with a rubber mallet. They should come lose.
Old May 16, 2010 | 11:15 PM
tmnhs81's Avatar
Originally Posted by TLin401
Impact screwdriver
It will round it out and then you are screwed even more.
Old May 17, 2010 | 01:48 AM
myisanog's Avatar
lift more weights
Old May 17, 2010 | 08:31 AM
Mandy's Avatar
Where do I spray the WD40? I had PB blaster on the screws. Tap on the center of the rotor?
I also put in 2 bolts into the bolt holes, still will not budge.
I will try the tapping. Patience. That's what I need. I have tried every imaginable way to loosen that screw. I actually bought an impact wrench for this purpose when I did my CRV door latch actuator change. But did not need it, I was able to use brute force, but the screws are bigger, too.
The rotor screws are so tiny and will end up being rounded.
I will try the tapping....
Mandy's Avatar
Wink
Originally Posted by myisanog
lift more weights
I tried that too. Did not work. LOL!
Old May 17, 2010 | 09:35 AM
Mr. Maker's Avatar
Originally Posted by Mandy
tapping. Patience. ...
Old May 17, 2010 | 12:27 PM
TexasHonda's Avatar
The 98 has rotors above the hubs I believe, so the 2 screws are all that holds the rotor in place once lug nuts are removed. My understanding is these screws are not necessary and may be drilled out. Once screw heads are drilled off, you can remove the rotor and extract the stubs w/ vise grips or leave them in place if they won't back out. No need to replace.
good luck
Old May 17, 2010 | 07:48 PM
desired_speeds's Avatar
Impact screwdriver
thats what I use.
that won't happen if you use the correct size screwdriver bit. I've removed screws that were borderline stripped without any issues.
Old May 17, 2010 | 08:06 PM
Mandy's Avatar
good luck
That's my plan B. Thanks. In due time, I shall remove the rotors.
mada51589
Jan 9, 2025 04:40 PM
08 NBP TL
Sep 8, 2015 08:49 PM
mav888
1G RDX (2007-2012)
Sep 8, 2015 11:49 AM
truonghthe
Sep 7, 2015 11:17 PM
