Door Lock Acuator?
Old Jul 13, 2007 | 07:27 AM
deadsetonlivin's Avatar
Door Lock Acuator?
Anyone know how to install one??
Old Jul 13, 2007 | 03:31 PM
Go90go's Avatar
大日本帝国
Did you get a universal one or a direct replacement? All you need to do is pull off the door panel, peel back the plastic sheet, unplug and unscrew.
~Cheers~
Old Jul 31, 2007 | 10:22 AM
I got this universal one
http://www.amazon.com/Wire-Door-Actu...5895207&sr=1-6
It doesn't even remotly look or work like the one thats in there currently. Any ideas? Where can I find a OE one? Or will this one work?
Old Aug 1, 2007 | 02:24 PM
anyone??
Old Aug 1, 2007 | 08:45 PM
Go90go's Avatar
大日本帝国
Sorry, been busy as you can see from my other thread, ! Anyhow, should be relatively simple, but it's been awhile since I had the rear door off so forgive me if I describe it wrong. IIRC, the lock/unlock sequence is just reversing the polarity of the actuator, so the two wires is all you need. However, I believe that there was an extra wire that might've sent a signal to the security module to signal that the door HAS completed the lock cycle (see desired_speeds' thread on door locks). This isn't essential to the system, as mine is completely disconnected and the stock system arms just fine. Best thing is to trace the stock one on the door with a grease pencil or something to see where the hooks went originally, then try and mount the new one with the supplied bracket, and get it aligned right. Good luck, and if anyone else wants to chime in, please do.
~Cheers~
Old Aug 1, 2007 | 10:02 PM
96teeluxury's Avatar
Tri State ViP Crew
what does this do?
(nub question)
Old Aug 1, 2007 | 11:46 PM
lol to tell you the truth... idunno but mines makes a funny noise..
Old Aug 2, 2007 | 03:53 AM
Go90go's Avatar
大日本帝国
Originally Posted by 96teeluxury
what does this do?
(nub question)
The actuator is what actually does the locking/unlocking of your door. It's a small motor with a 60* gear.
~Cheers~
Old Aug 19, 2007 | 12:41 AM
Which honda/acura uses the same acutuator? They yard close to me dosen't have any TLs.
Old Aug 19, 2007 | 05:34 AM
Go90go's Avatar
大日本帝国
Could be Legend, but I'm sure you can make another Honda one work. Try Integra sedans, . They use the same/similar door handles so it should work.
~Cheers~
MrHeeltoe
20
Feb 23, 2023 01:54 PM
soupi
14
Nov 15, 2015 11:15 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
DementiaPhuro
Sep 29, 2015 05:31 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
