Diffential Removal
Old Jan 21, 2011 | 10:24 PM
deejayphilo's Avatar
Diffential Removal
I need help in removing my differential. I got the trans axle out both sides, got all the bolt out. The differential is open from the engine block about 1inch but still not dropping. Is it because of the connecting shaft from the tranny holding the differential to drop?
Old Jan 22, 2011 | 01:10 AM
9632tl's Avatar
Radical Member
Why are you removing it? Just curious
Old Jan 22, 2011 | 02:07 AM
Go90go's Avatar
大日本帝国
Did you remove the sealing bolt? It's the flat disc with a square opening. You can use a 3/8 ratchet to turn it, IIRC. I got it out without doing that, but it's much easier and the proper way to do it by removing that and the shaft with a special tool from Honda.
~Cheers~
Old Jan 22, 2011 | 11:27 AM
Where is d sealing bolt can u provide me links were I can see it? Coz I think all d bolt is out
Old Jan 22, 2011 | 01:16 PM
Go90go's Avatar
大日本帝国
It's on the transmission bell housing, right where it's stuck for you.
~Cheers~
Old Jan 22, 2011 | 02:08 PM
TexasHonda's Avatar
If you don't have an Acura Shop Manual, you are aksing for problems/damage.
Shop manual indicates the sealing bolt and extension shaft must be removed.
VSS/Power Steering speed sensor must also be removed.
Get a manual!
good luck
Old Jan 22, 2011 | 02:50 PM
The sealing bolt is the first bolt i removed. I think thge shaft is engaged with the differential. THe differential is hanging already. All the DOWEL pIN is off too so it should drop. Maybe it just need a snug........
Old Jan 22, 2011 | 05:27 PM
Go90go's Avatar
大日本帝国
That shaft is what needs to be removed, but try a pry bar and wedging it where the P shaped washer was. Make sure the diff is straight against the motor while doing this so you don't bend anything.
~Cheers~
Old Jan 23, 2011 | 09:04 AM
desired_speeds's Avatar
you need to pull the output shaft on the tranny out a few winches before the diff will come loose.
Old Jan 23, 2011 | 01:56 PM
How will I pull the output shaft though
Old Jan 23, 2011 | 02:10 PM
yah I think it is the output shaft holding the differential. But I tried everything to cut it lose
Old Jan 25, 2011 | 09:53 PM
remove the sealing plate (where the 1/2 socket fits into is the sealing plate) it unscrews counter clockwise. I'm not sure how you're gonna do that with the axles disconnected. after you remove the sealing plate, there is a threaded hole that you can put a 12 or 14mm bolt (i forgot the size) into it, throw a big flat washer (a washer the size of your shock mount ones) onto the bolt and screw the bolt in. with the end sticking out. using the washer for leverage, pry outwards and the shaft will pull out towards the back of the car. you only need to have it come out a few inches and the diff will come out.
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
dainmezron
Oct 16, 2015 06:56 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
lowgrowl
Sep 26, 2015 05:18 PM
